72 control valve leak
Old Jan 23, 2011 | 04:17 AM
riverracer au's Avatar
riverracer au
Default 72 control valve leak
from the photo's, can someone tell me whats wrong with it, and how to fix?
do i have to remove it from the car to fix?
looking thru the suppliers, there seems to be 2 different kits, 1 with ball stud, and the other with 'o'rings. which do i need?
or do i just need to replace the boot?
the thin wire in second photo holds a rubber dust cap on.
it started all of a sudden, like with in a couple of weeks!
thanks
Old Jan 23, 2011 | 05:21 AM
7T1vette's Avatar
7T1vette
Looks like a bunch of excess grease dripping down from the steering joint right above it. Clean off the grease and you'll be fine. Now, if you have other P/S fluid leaks from the control valve after you clean it up, it will be coming from the hoses...which you can replace without messing with the control valve...or the valve gaskets/seals. In the latter case, you will need to remove the control valve and do a fairly simple rebuild (low buck fix) or replace it [with foreign junk]. I think you know which I would do.
Old Jan 23, 2011 | 10:03 AM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Looks like somebody has been pumping grease into the zerk fitting on the control valve.
Old Jan 23, 2011 | 11:38 AM
Hammerhead Fred's Avatar
Hammerhead Fred
If you're referring to the grease:
Looks like it was simply over greased.
I'd wipe it down as described previously and see what happens.
It's possible your ball stud valve boot split and if so you'll need to replace it sooner or later as it keeps the grease on the ball and dirt out of the joint.
Also possible that the metal strap that holds the valve boot in place is simply broken.
If you're referring to the couple of pink fluid drips in the second photo then you'll need to post better photo of your issue. If the steering is smooth then no need to replace the ball stud etc. and go with the seal kit.
Old Jan 23, 2011 | 11:52 AM
speedreed8's Avatar
speedreed8
how to:
http://www.cssbinc.com/images/ads/ho...structions.pdf
Old Jan 23, 2011 | 02:57 PM
Hammerhead Fred
Originally Posted by speedreed8
NICE!
Old Jan 23, 2011 | 02:58 PM
riverracer au
if by 'zerk' fitting you mean the grease nipple, then no, i have not greased that.
the steering is smooth, all tho slight play in the wheel, less than 1" side to side.
will wipe it down to see if i can pin point where it's coming from better.
thanks
Old Jan 24, 2011 | 12:40 AM
Manuel Azevedo's Avatar
Manuel Azevedo
It is possible that you have the lip seal and possibly an "o" ring leaking in side. The lip seal seals the piston chamber from the pivot ball side, so if the seal leaks to the ball it would push out the grease as well as some steering fluid also. The link that speedreed8 posted is real good, check it out and you will see the lip seal I'm talking about. looks like you need a rebuild there.
Old Jan 24, 2011 | 09:26 AM
damoroso's Avatar
damoroso
If it's only grease, the rubber boot that's supposed to hold it in has likely torn from use, not too big a deal. If it's grease mixed with power steering fluid (if it starts dripping) it's rebuild time.
To 72 control valve leak
