L89 Aluminum head date code location
Old Jan 25, 2011 | 03:53 PM
mlc48's Avatar
mlc48
Default L89 Aluminum head date code location
Hi
Does anyone know where the date code is located on Al head 3919842. Can it be seen with head on engine I'm trying to verify a #s matching L89 vette
Thanks MLC48
Old Jan 25, 2011 | 04:32 PM
Alan 71's Avatar
Alan 71
Hi mlc,
The valve covers need to off the heads to see the date castings.
Good Luck!
Regards,
Alan
Old Jan 25, 2011 | 08:02 PM
68-427Rich's Avatar
68-427Rich
Default Casing date
On most BB aluminum heads the date is cast on the bottom of the intake port.
Old Jan 26, 2011 | 05:46 AM
WESCH's Avatar
WESCH
Hi
That is what I thought too.
The cast heads have it under the valve cover, but the alus have it unvisible as long as the intake is installed.
Hence unvisible for NCRS judging.
Rgds. Günther
Old Jan 28, 2011 | 12:21 PM
mlc48's Avatar
mlc48
Thanks guys that's what I thought also
MLC48
Old Feb 6, 2011 | 02:22 AM
Gale Banks 80''s Avatar
Gale Banks 80'
It might be possible to see it with a Bore a Scope. They are used in the Large Diesel Engine world do look into Cylinders with out removing the Heads. One might be able to remove an Intack Bolt and go down threw its Hole, if not for sure down the Distributor Hole. As said above, the NCRS can't see it so it must be right.
Old Feb 6, 2011 | 11:26 PM
babbah's Avatar
babbah
I have the same heads on my BB and the date code is stamped to the left of the third intake valve spring (on pass side) - third intake runner. (Second intake runner if on driver side) Dates are stamped vertically. They are identical out of the box.
Simply remove the valve covers. The date codes are both stamped in this area. The part number is right above them slightly to the right and displayed horizontally.
The original L89 heads are not this number. The ones you have are Chevrolet Factory replacements #3919842 - aluminum closed chamber rectangular port heads.
To L89 Aluminum head date code location
