Nice launch Clint!! What are you running for power in that?? BTW, I'm sure having Mike do your rear was less expensive than the iron conversion. Off the top of my head, I'd guess mine was around $1100 including the rebuilt diff.
There is only one person I would trust machining and installing a steel cap in an aluminum diff, and he is right here on the forum. He's been doing it for a while now, and he has all the jigs set up. Check out this monster...
If you wanna keep your diff together, I would go this route. Just some advice.
So who is this person making these caps and what kind of $$$ are we talking? I need to do a gear change and rebuild this spring/summer and would like to up grade everything before putting it together.
Mike is tracdogg2, or so I gathered from the posts.
I figure I'm putting about about 450 HP. Not too bad for a street legal machine.
3500 stall, that explains it!! I'm running a warmed up big block in my 81, but I'm running a much tighter converter so I don't get a launch anything like that!!
If you got a Big Block up front your gonna need alot more than a converter to lift that hunk of iron up
From: Graceland in a Not Correctly Restored Stingray
Why does this propaganda persist? They aren't as heavy as you might believe; an alum head, intake and water pump BB weighing in at less than 100# over an L82.
Yep, and do not forget an Aluminum radiator as well. I think that is good for a few pounds less than the stock copper. I have all the above you mentioned, I do not think its much heavier than my old L83.
Stu, contact tracdogg2 , he will provide you information on the steel cap for the alum rear end.
