What is the weakest (or simply weak) link in the rearend setup of an '81 Vette? I'm redoing the one in mine now for a 383/twin-turbo street project. I've been through the diff with all new bearings, 3.08 gear, solid 1330 U-joints in the stock 3" half-shafts...etc. What else can be done with stock stuff to get it to hold up? What usually breaks first? Second? Thanks.
The 1330 U Joints go 1st. The Posi Clutchs rub on the Carrier and dump metal into the oil and do in the Bearings next. The 1980 4 speed and all 1982's used 1350 U-joints wich hold up better. Yokes, 1/2 shafts and Axel Flanges are needed to install them.
Most of the high power guys that are running the iron diffs install one billet cap, I'd think the aluminum one would benefit from one as well. I decided not to spend the coin on a weak diff, I'm upgrading to iron along with bigger halfshafts, U-joints, etc.
I went with an iron differential. It's not that hard to do, and it not only improves the strength of the rear end, it improves the handling too. You have to use the struts from the earlier differentials, and that puts the struts parallel to the half shafts, improving the suspension geometry.
Damoroso:
Thats the coolest thing I've seen.......iron rear on the 1981 aluminum cross member.
Does it just bolt in or did you have to re-drill the mounting holes?
What else is involved in the switch?
Thanks! Others have done this and it's as close to a "bolt in" mod you'll find. The iron unit bolts directly to the batwing, though you won't use two bolt holes. No big deal, no leaks and no weakness either. You will have to buy early (pre 1980) half shafts, axle flanges, strut rods and mount, and a pinion mounting bracket for the earlier cars too. The half shafts and flanges bolt right in, as do the strut rods. I did have to modify the pinion mount, I had to cut about 3/4" off the front (so it would clear the frame), and had to drill a new hole for the bolt in line with the pinion bushing mount on the frame. I also had to trim the strut rod mount for my exhaust pipes. This might also be a good time to do anything to the trailing arms that needs done. I did my bushings, and added a rear sway bar.
I got all my parts from Van Steel, if you call them, they can put all the parts together for you, they've seen this done many times.
From: Graceland in a Not Correctly Restored Stingray
Sorry, that last part isn't necessarily true. Optimal camber gain geometry depends on a number of factors, including one's purposes.
There is only one person I would trust machining and installing a steel cap in an aluminum diff, and he is right here on the forum. He's been doing it for a while now, and he has all the jigs set up. Check out this monster...
If you wanna keep your diff together, I would go this route. Just some advice.
Your right, not gospel, but as I understand it (I could be wrong, hell, it's not even 10am and that's already happened today!!) the new (new-old!) struts and their geometry when compared to the stock set up improves the rear stability of the suspension in general. Is this not true?
"Stability" when used to describe general improvement may be somewhat of a vague term when it comes to the fine details of suspension dynamics. The degree of camber strut bushing compliance indeed plays a role in the geometry, but the relationship of the struts to half-shafts is the primary factor in determining camber gain. Less or none is great at the drag strip, but some amount is typically desired for pretty much any other type of driving. I commonly suggest following John Greenwood's advise to lower the inner camber strut links ~1/2" below C3 OEM height unless one actually tests to prove a better adjsutment for their particular application. My appologies to the OP for the sidebar, but hope it's worth $.02.
Oh I like the discussion. I have heard first hand that the aluminum center is not the weakest link. I've seen many convert 80-82s to an iron center and leave the other parts stock. Why? There are high HP cars out there using a stock aluminum center but with beefed up components (half shafts, outer axles, u-joints, etc). I converted my '81 over to Brute u-joints, drilled all the flanges/yokes to accept 5/16" U-bolts, and installed shaft loops. Other than replacing parts, that's about all I can do right?
i been flogging a stock (apart from 355 gears ) 81 dana44 rear now for about 3 years with 420hp and 295 rear tyres. i admit i dont spend any time on a sticky track but i give it heaps on the street and so far...so good.
I don't know what you mean when you say the put an iron center in and left the other parts stock. The stock half shafts won't fit (the iron unit is narrower than the alum.) and they require flange plates vs. yokes at the axles. The stock strut rods won't fit either, the mount differently on the alum and iron units. My alum unit might not have failed, but after talking to Mike, Gary and others, I decided to do the conversion. Hell, I wanted to change gear ratios anyway, so, while I was at it....
Most people believe that the Spicer Brand U-Joint is the best avalable. A 1350 U-Joint is larger and there for stronger than a 1330.
There is a guy on here, with an Red 82, 3.70 gear, 383 stroker with some juice, 3500 stall, and I think 700 r4 trans. He runs 11.90s and can pull the front wheels. He needs to chime in. I think his diff is stock, but rebuilt. This is from memory only. I had to take note of it, because he changed my view, of the dana 44s that are " so weak "
I found the thread
Try searching for forum member = Clint`s C3 ( My First Wheelie ( that I know of ) is the thread title ) check it out
I found the thread
Hey, thanks for the shout out but it's 11.30 and 1.49 60's thanks very much.
Mike Dyer just machined and installed a steel bearing cap (it looks like the picture posted by Stinger 12) and rebuilt the diff and training arm assembly. A beautiful job and darn site less expensive than an iron diff conversion. We start racing again in about 3 weeks and I'll keep eveyone posted.
Hey Clint, I'm in Irving, close by to you.......is Mike Dyer close by to us? I have an 1981 Vette that needs an iron bearing cap and new gears. Thanks!
Nice launch Clint!! What are you running for power in that?? BTW, I'm sure having Mike do your rear was less expensive than the iron conversion. Off the top of my head, I'd guess mine was around $1100 including the rebuilt diff.
