Help With Mechanical Driven Tachometer
Old Feb 1, 2011 | 09:43 PM
goldenfox's Avatar
goldenfox
Cruising
Default Help With Mechanical Driven Tachometer
My 74 Vette has a mechanically driven tachometer. It doesn't work. The distributor is an aftermarket Excel model 30100T, which seems to be obsolete; it doesn't appear any longer in reference books. My observations are that the tach drive gear is pretty well toast. Although the main drive gear hasn't been removed, I suspect it is too. While the parts people say it won't be difficult replacing the main gear, finding the tach drive gear is another story. Can anyone help me with locating the necessary part so that the tachometer will function properly.
Thanks.
Fox
BTW, the car runs beautifully with the existing distributor; I just want the tachometer to work.
Old Feb 1, 2011 | 10:14 PM
1969RAY's Avatar
1969RAY
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
I would guess that it's the same for all tach drives. Eckler's, Zip, Corvette Central, all will carry that gear. Good luck, it's nice to have a working tach.
Old Feb 2, 2011 | 11:14 AM
annasvett's Avatar
annasvett
Cruising
i have a 74 too with tach problems...mine is the tach cable breaks inside the tube because i run such a high advance that it hits the fire wall but thats probable not your problem.... what main gear is not working? the one in the dist. or the gears in the actualy tach?
Old Feb 2, 2011 | 11:36 AM
Paul L's Avatar
Paul L
Have you made this adjustment?
Old Feb 2, 2011 | 04:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You can get reproduction stock tach drive distributors.
Have you checked the cable to ensure it's good?
Old Feb 2, 2011 | 04:58 PM
mrvette's Avatar
mrvette
75-77 vette has electronic tach, and far better/reliable than any mechanical POS....
do what I did 15 years ago....switch it out...and never look back...
I got lucky and swapped my old mechanical drive points dizzy for one with the local vette shop owner....
Old Feb 3, 2011 | 12:11 PM
annasvett's Avatar
annasvett
Cruising
i just bought a 90 degree mech tach adapter.... i should have tried that first
To Help With Mechanical Driven Tachometer
