Rochester Idle Mixture Screws
Old Feb 5, 2011 | 11:24 AM
1986coupe's Avatar
1986coupe
Default Rochester Idle Mixture Screws
I am frequently adjusting my idle mixture screws. I make an adjustment then in no time the screws have moved and I have to re-adjust. Is there any reason that the screws are slipping? Is something on the carb missing or should I use some sort of lock tight on the threads?
1986coupe's Avatar
1986coupe
Oooops. Forgot to mention this is on my 1976 L-48 Auto.
Old Feb 5, 2011 | 11:39 AM
jimboscarbs's Avatar
jimboscarbs
There should be springs between the adjustment screws and the carburetor base
Old Feb 5, 2011 | 11:43 AM
7T1vette's Avatar
7T1vette
Right! Those springs prevent the screws from vibrating loose. If there are no springs on the threaded shaft of those idle screws, they will loosen. You should be able to buy some 'general purpose' springs that will work at any hardware store; they are not "flimsy" and have wire diameter of about .030" and are about 1/2" long.
Old Feb 5, 2011 | 12:03 PM
1986coupe's Avatar
1986coupe
Thanks! I am better with FI than I am with carburetors. With experience I will get better.
Bill
Old Feb 5, 2011 | 12:24 PM
1986coupe's Avatar
1986coupe
I just looked. Springs are there but probably weak since the mixture screws turn themselves loose so easily.
Old Feb 5, 2011 | 12:27 PM
jimboscarbs
you may be able to get away with just replacing the springs, how is the idle quality?
Old Feb 5, 2011 | 01:50 PM
1986coupe's Avatar
1986coupe
Once I make the adjustment the quality is fine. It will run fine for a few days then it becomes noticeable that the idle quality is changing. I noticed how bad it is today because I decided to warm it up in the garage....makes me feel like spring is here soon
Old Feb 5, 2011 | 02:00 PM
jimboscarbs
is there any fuel dripping from the primary boosters?
is there alot of play in the primary throttle shaft?
Reaosn being if there is air coming from some place it's not suppose to be you may be compensating for this by having to back out so far on the idle adjustment screws that it relieves the retaining tension of the springs. Genreally if the idle circuit has not been resized the adjustment screws end up about halfway out on a healthy engine.
FWIW,, Jimbo
Old Feb 5, 2011 | 03:53 PM
1986coupe's Avatar
1986coupe
Normally I only need to seat the screws then turn them back about 1 turn and the car idles fine. This morning I had to turn them more than three complete turns to get them to seat again. That is how far out it went in such a short time.
Old Feb 5, 2011 | 06:41 PM
7T1vette's Avatar
7T1vette
Yep. You need stiffer springs. Or, you could put a "locknut" on each threaded shaft, then snug it down once you've set the idle on each screw.
Old Feb 7, 2011 | 09:22 PM
scottyp99's Avatar
scottyp99
I would think that if you know where the screws like to be, (one turn out) just back them out about 5 turns or so, a drop of loctite, and screw it back in. Done and done.
If anyone can think of why this might be a dumb idea, hurry up and let us know, before he tries it.
Scott
Old Feb 7, 2011 | 10:21 PM
OMF's Avatar
OMF
Hey.....the locktite idea was mine....great minds think alike
Old Feb 8, 2011 | 09:50 AM
78 C3 Light Corvette Blue's Avatar
Acct suspended by request 19 April 2011
blue locktite
Old Feb 8, 2011 | 10:21 AM
Snoopysvet's Avatar
Snoopysvet
Originally Posted by 78 C3 Light Corvette Blue
blue lock tight
LOL - I guess you got a good point there!
To Rochester Idle Mixture Screws
