Vacuum line
Old Feb 14, 2011 | 10:52 AM
dalecarlson's Avatar
dalecarlson
Cruising
Default Vacuum line
Does anyone know how the vacuum line runs off the intake manifold of a 68, L36 with air conditioning and what parts are needed? I think it’s not the same as other Qjets. If you can see the C60 section of AIM, view B, of C60, C8. There is a cap on the front of the carb and a “Y” fitting on manifold. Boy a picture of the thing would help.
Dale
Old Feb 14, 2011 | 01:40 PM
Alan 71's Avatar
Alan 71
Hi Dale,
Are you asking about the vacuum supply line for the wiper and headlight doors or for advance?
Regards,
Alan
Old Feb 15, 2011 | 12:30 AM
dalecarlson
Cruising
Default Vacum advance line
Alan
Its the advance line off the rear of the intake that has a "Y" fitting. Where the lines run from there is what I would like to know. The book says one is a vacum hose the other a prod spark hose. Then it shows a cap over the front of the carb where the non A/C cars.
Thanks for you help
Dale
Old Feb 15, 2011 | 08:08 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I agree with Alan; I think its the supply for wiper and headlight vacuum. I also agree the AIM page is not as clear as it could be, but it worked for assembly line folks.
To Vacuum line
