69 Headlight Wiring Harness Removal
Old Feb 17, 2011 | 03:30 AM
M A Fry's Avatar
M A Fry
Default 69 Headlight Wiring Harness Removal
G'day Everyone,
Just wanted to know how you remove the front wiring harness plug from the back of the fuse block of a 69 vette. I have been trying to pull mine straight off from inside the engine bay, is this correct or do I need to remove the fuse block form inside the cabin and then prise it off?
Regards,
Mark
Old Feb 17, 2011 | 06:39 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
I believe there's a bolt in the middle of it that you need to loosen.
No need to do anything on the inside.
Old Feb 17, 2011 | 08:07 AM
...Roger...'s Avatar
...Roger...
If I remember right it will take a 3/8" socket to loosen the bolt.
I believe the bolt is retained in the plug so it will come off with the plug.
The plug is 2 pieces and they interlock so you have to pull both off to separate the headlight harness.
Old Feb 17, 2011 | 08:23 AM
Alan 71's Avatar
Alan 71
Hi,
In addition to the bolt there's often a good bit of black water-proof sealant on the plug connection that needs to be loosened too.
Regards,
Alan
Old Feb 17, 2011 | 05:57 PM
M A Fry's Avatar
M A Fry
Thanks Fella's.
I can always rely on the members of this forum to head me in the right direction with good info!!!!
To 69 Headlight Wiring Harness Removal
