1979 power windows help
Old Feb 17, 2011 | 03:34 PM
behardt91's Avatar
behardt91
Default 1979 power windows help
Does anyone know which fuse power runs through to power windows on a 79? And what circuit are power windows a part of? My windows are not currently working. A schematic might help.
Old Feb 17, 2011 | 04:34 PM
...Roger...'s Avatar
...Roger...
The 79 is pretty simple,it uses a 30 amp circuit breaker and no relay.
Breaker is on right side of fuse box above turn signal flasher and its labeled PWR ACCY.
Old Feb 17, 2011 | 04:35 PM
1yy07's Avatar
1yy07
yhere is a 30 ampcircuit breaker in the fuse box
Old Feb 17, 2011 | 05:42 PM
behardt91's Avatar
behardt91
well, the fuse isn't bad. I just checked it. But it looks like the window switches don't have power going to them when you flip the ignition.
Old Feb 17, 2011 | 07:17 PM
...Roger...
If you have power on both sides of the circuit breaker the next thing is to check the 12 pink at the switches.
(Don't be fooled by a corroded connector on the fused side of the circuit breaker-probe both the spade and connector to be sure.)
Old Feb 17, 2011 | 07:55 PM
behardt91's Avatar
behardt91
Whoever had my car last replaced the breaker with a fuse but the fuse is good and the windows used to work. There is no power at either of the window switches. So there is something wrong with the wires in between the fusebox and the window switches.
Old Feb 17, 2011 | 08:36 PM
behardt91's Avatar
behardt91
On the circuit breaker above the the a/c fuse, there is the pink wire and the circuit breaker. This part of the fusebox doesn't have power when the key is turned. I looked in the AIM and this wire to the fusebox is labeled Power Window. Does anyone know where the slot gets its power?
Old Feb 17, 2011 | 08:54 PM
speedreed8's Avatar
speedreed8
slot get its power from igntion switch on top of lower steering column,
http://www.corvetteforum.net/c3/tune...l/index8.shtml
http://www.corvetteforum.net/c3/tune.../index22.shtml
To 1979 power windows help
