Cam Change!
Old Feb 21, 2011 | 05:54 PM
trainor's Avatar
trainor
Default Cam Change!
I decided to put a bigger cam into my 75 L48. Just did a complete rebuild on it and I let the builder talk me into a Crower 241 cam Has a lift of 456. I also put on Brodix IK 180 alum. heads, performer intake, 650cfm edelbrock (Weber), shorty headers. Iv'e got a dyno at about 350 at the flywheel. With all this good stuff I want some better sound out of the cam and more HP at the same time. The cam thats in it now has zero lope to it. Contacted Comp cams and they suggested part # 12-246-3. Has a lift of 490. Well what do you guys think, will this make this motor sound alot better. I want a noticeable lope but don't want vacuum problems or idle problems. The Brodix heads will handle a cam up to a 525 lift. Any input? Thanks Guys.
Old Feb 21, 2011 | 07:53 PM
trainor's Avatar
trainor
Default C'mon Guys, Help Me!
Can somebody give me some insight on a cam?
Old Feb 21, 2011 | 07:55 PM
LB66383's Avatar
LB66383
What do you use the car for? Any racing? Just cruising around town? To get that lope you're looking for takes more duration as well as more lift. And that moves your power band up the rpm scale. You can end up with very little power below 3,000 rpm or so. Which would be no fun around town, if you have to wind the engine to 6,000 rpm to enjoy the power.
It is also possible to over-cam an engine. What is your compression ratio? If you're running 9 or 9.5 to 1, a radical cam is going to make it run worse, not better.
Old Feb 21, 2011 | 07:58 PM
trainor's Avatar
trainor
I'll mainly be using it to cruise around in. Compression is at 10 to 1. But is a 490 lift cam that radical?
Old Feb 21, 2011 | 08:46 PM
Indiancreek's Avatar
Indiancreek
Find or have ground a mild solid roller cam. It will sound great and be very streetable. They are difficult to find is why I suggested having one ground with a mild profile.
If you are running an auto tranny and get to wild you'll run into stall speed converter issues.
Old Feb 21, 2011 | 08:55 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Cam lift has almost nothing to do with how radical it is.
What creates an idle with a lope is duration and overlap.
Look for a cam without too much duration, but with a tight lobe separation angle, and you can get a nice lope without suffering too many "big cam" issues.
Old Feb 22, 2011 | 09:45 PM
Jack Wood's Avatar
Jack Wood
Default Look for a cam with 108-110 degrees of lobe separation angle.
That will give you the sound you're looking for.
Old Feb 23, 2011 | 12:05 AM
7t9l82's Avatar
7t9l82
another thing to consider is a bigger carburetor with those heads and a cam it has to be leaving power on the table. on a stock motor fine but not your motor
Old Feb 23, 2011 | 12:24 AM
GS977's Avatar
GS977
.490 lift is not radical. if you want a good sound with some lope, go for a cam with @ .500-.525 lift and @220-228 dur @.050 and a 108-110 sep. this is with a stock or 1500-1800 stall convertor.
good luck
Old Feb 23, 2011 | 12:29 AM
Scott Marzahl's Avatar
Scott Marzahl
The cam comp recommended XE274 would be a good match for your build 230/236 degrees and give you the sound you are after since its ground on a 110 LSA. Another good cam that will be good with your build would be the Comp 270 Magnum it doesn't have the extreme ramp rate on the lobes like the XE series and would be a little easier on the valve train wear. [IIt would have more low end torque than the XE274[/I]Duration @ .050'' Lift: 224° Intake / 224° Exhaust
Valve Lift w/1.5 Rockers: .470'' Intake / .470'' Exhaust
Lobe Separation Angle: 110°
The Crower specs are 214°/218° @0.050" which is pretty tame for an engine with 10:1 compression. The L82 cam is 224/224 to give you an example how small the Crower is.
To Cam Change!
