Need tips for carpet install
Old Feb 24, 2011 | 09:11 AM
jcloving's Avatar
jcloving
Default Need tips for carpet install
I need tips/tricks/wisdom for installing new carpet in my 76 Stingray.
I have already laid down new hushmat and reflectix. I still have my old carpet.
Thanks,
Old Feb 24, 2011 | 10:04 AM
75+78 Corvettes's Avatar
75+78 Corvettes
Thanks,
Lots of thread out there. Here's mine from another forum
Interior replacement thread
Start from the front and work your way back This way you will start with the easy part and finish with the hard by which time you will have the practice to do it right. Don't cut anything until it is glued down in place.
Old Feb 24, 2011 | 11:52 AM
7T1vette's Avatar
7T1vette
Once you get the carpeting installed, use a very large stitching needle (for leather?), or a strightened paper clip with a sharpened end, to search for the holes that need to be made for the various fasteners (seat rail bolts, T-top strap holders, seat belts, etc.). Once found, mark that location with chalk or similar method, then use a pencil-type soldering iron to melt the hole where you need it. Keep water or fire extinguisher near...just in case. (I've never had one catch fire; but better safe than sorry.) Melting those holes is much better and cleaner than cutting them. P.S. Don't breathe the smoke!
Old Feb 24, 2011 | 12:08 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Wear knee pads! I remember the interior job on my '76 very well. I'd rather pull an engine. While apart, replace the foam seals in your ac/heater box and do the heater core too. There is no better time.
Old Feb 24, 2011 | 01:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The diagrams in the AIM can be helpful. Not a How To, but a place to check every now and then.
Old Feb 24, 2011 | 02:03 PM
Alan 71's Avatar
Alan 71
Hi,
The most difficult pieces are the 2 over the rear wheel-wells. They take a lot of fitting and trimming.
I agree that you shouldnt cut anything until you're ABSOLUTELY sure; and then only a little bit at a time.
Also, 7T1's points about using a needle and a soldering-iron are the way to go.
Carpet can turn out really well if you take your time.
Regards,
Alan
Old Feb 24, 2011 | 05:26 PM
jcloving's Avatar
jcloving
Thanks for the great tips. I will try them all.
Old Feb 24, 2011 | 07:01 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Also it is a good idea to put the carpets under the sun for a while so they become more flexible, that will make them much easier to lay them inside the car.
To Need tips for carpet install
