replacing the reverse switch
Old Feb 24, 2011 | 09:38 AM
desertdogs50's Avatar
desertdogs50
Cruising
Default replacing the reverse switch
Alright, I ordered a new reverse light switch for my 78, and of course the repair manual nor the part itself came with any gouge. If anyone has prior experiance with replacing this switch much appreciated before I rip the console apart.
Old Feb 24, 2011 | 01:26 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
is this a 4 spd reverse light or the automatic neutral safety switch/reverse light switch?
Old Feb 24, 2011 | 01:39 PM
desertdogs50
Cruising
4 speed reverse
Old Feb 24, 2011 | 01:42 PM
bobs77vet's Avatar
bobs77vet
sorry cant help you.....however is it mounted from below? it may not be accessed through the console. it may be coming off a shift linkage as opposed to the actual shifter.
Old Feb 24, 2011 | 02:13 PM
desertdogs50
Cruising
No problem, I wish it was that simple, I just had my transmission overhauled and that was the first thing I looked for, now I need to get into the console. Thanks.
Old Feb 24, 2011 | 02:50 PM
billsfan's Avatar
billsfan
On my '76 it is located on a bracket next to the reverse gear lever on the transmission, with a short piece of linkage running to the gear lever. One wire leads up to a plug, and then to the engine harness. Takes 5 minutes to replace.
Old Feb 24, 2011 | 03:01 PM
A88FXRS's Avatar
A88FXRS
switch is on trans with small linkage. work from underneath, much easier.
Old Feb 24, 2011 | 03:12 PM
desertdogs50
Cruising
Thanks I will look for that.
Old Feb 24, 2011 | 03:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
No need to get into the console. Sounds like the overhaul folks did not reinstall it or did not plug it up well.
Old Feb 24, 2011 | 03:28 PM
BKarol's Avatar
BKarol
Does your replacement look like this? there is a tech diagram to your right.
http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
Old Feb 24, 2011 | 03:32 PM
desertdogs50
Cruising
Excellent, that helps alot, the mechs working the transmission said thier were no brackets or switch, they are getting the bracket for it sent from oregan overnight, lots of help. Thank you.
Old Feb 24, 2011 | 03:35 PM
desertdogs50
Cruising
Right, it was missing prior to thier tear down, previous owner must of messed with it some how. thanks for the info.
Old Mar 10, 2025 | 11:36 AM
Mike Oliver's Avatar
Mike Oliver
5th Gear
Default 78 Corvette reverse switch
[IQUOTE=desertdogs50;1576884475]No problem, I wish it was that simple, I just had my transmission overhauled and that was the first thing I looked for, now I need to get into the console. Thanks.[/QUOTE]
The reverse light activation comes from a small bracket connected to the trans side cover with a small rod that connects to the reverse arm
To replacing the reverse switch
