monoleaf
Old Mar 1, 2011 | 11:44 PM
BadBaran's Avatar
BadBaran
Default monoleaf
I have an 81 and am currently rebuilding the rear. I got 3.54 gears put in the rear and have Van Steel offset trailing arms and adjustable strut bars. So I want to get a new monoleaf. So are all of them equal? I have looked around and many places have them for many different prices. Is this a you get what you pay for or are they all pretty equal. Also any recommendations for what resistance size. I was thinking about going with a 360. Thanks for any input
Old Mar 2, 2011 | 07:01 AM
7T1vette's Avatar
7T1vette
If the car 'rides' well and there is no damage/fraying of the monoleaf spring, there is really no need to replace it. That type spring does not "wear out". It's integrity is only limited by any damage to the outside surface. If it is not chipped, split, or frayed it should be reused....unless you wish to change the spring strength or rate for some reason. And from your post, I doubt that is your concern.
Old Mar 2, 2011 | 07:48 AM
jb78L-82's Avatar
jb78L-82
Your 81 and the 82's monoleafs are real marshmellows-198 lbs/inch. You need to match the spring rate in the back with the front springs. I would look for a rear spring with a rate of 300 + rating if you want a firmer ride and better handling along with possibly a very small rear sway bar which you probably don't have stock. Bistein heavy duty shocks (not the sports) will give you a good ride with better damping.
Old Mar 2, 2011 | 08:10 AM
nate99's Avatar
nate99
So you're saying the ride could get adventurous with the 540 lb. fronts I have on my '81?
I haven't made it back to deal with the rear suspension yet, but I was contemplating something stiffer as well. I'll see how it feels once i have it out on the road. It was tough to evaluate handling at all what with rotted out front suspension bushings.
Old Mar 2, 2011 | 09:11 AM
jb78L-82's Avatar
jb78L-82
I don't know what the spring rates are for the front springs on an 81 but I would think that 540(? more like 550 from the factory) would not be stock. I don't know if in 81 they still offered a base and sport suspension (in 82 I believe that they all came with one suspension-base and very soft). If you do have 540/550 front springs (which my sport suspension came with in 78) then you could go 360 rear monoleaf as I have had for 25 years now. With the Bisteins, I find my setup rides real well and I would go to 420 in the rear if I ever have to change the rear monospring but that's my preference only. Hope that helps!
Old Mar 2, 2011 | 09:25 AM
nate99's Avatar
nate99
I swapped out the stock springs for the 540/550 lb springs when I rebuilt my front suspension. It hasn't run since (getting closer), so I can't yet say how it rides.
Old Mar 2, 2011 | 04:20 PM
BadBaran's Avatar
BadBaran
I want to replace it with a 360lb. leaf. Now I am finding some are fiberglass and some are composite. What is the difference and is one better then the other?
Old Mar 2, 2011 | 05:02 PM
FKING1's Avatar
FKING1
Put a 330 on my 70 from Vette Brakes & Products.
Their stuff is first class.
Old Mar 3, 2011 | 01:58 AM
Gale Banks 80''s Avatar
Gale Banks 80'
If you have offset Trailing Arms arms then it sounds like You will be useing modern Wheel and Tires sizes. If so the TRW Style (Stock) is going to have clearance issues with the Rims. The VB&P Springs are not tapered at the ends and offer more clearance. The one that I have I have used for some 27 years or so so far. If you go with there Duel Mount Spring on your 81 your going to have Exhaust Clearance issues unless you use side pipes.
Old Mar 3, 2011 | 02:44 AM
BadBaran's Avatar
BadBaran
Yes I am getting some C6 Z06 wheels. I was looking at the vb&p 360 lb. spring. So it looks like that's my best bet. I am runnining side pipes so exhaust isn't an issue. I looked into the dual mount but not really sure its worth the 700 some dollars
Old Mar 4, 2011 | 01:54 AM
Gale Banks 80'
I have never used larger diameter that 17" but the Zo6 is at least 18" so this means You will have more Spring clearance. The end of the Spring will end up on the inside of the Wheel. The next issue will be your Sway Bar running into the Tire. A lot of people don't run a Sway Bar anyway. However by useing the Duel Mount you can for sure not use it no body dose.
Old Mar 4, 2011 | 02:52 AM
BadBaran's Avatar
BadBaran
Yea they will be 18 in the rear and 17 up front. In 81 they didn't have a sway bar but I am looking into adding one. I have seen a thread on here of how to make one work with wide tires
Old Mar 4, 2011 | 12:09 PM
redman76's Avatar
redman76
St. Jude Donor '09
I run the 550/360 VBP combo on mine with Bilstein Sport shocks and love the feel of the "sport" ride. Keep in mind that is with 15" tires/wheels.
Old Mar 5, 2011 | 07:48 PM
jb78L-82's Avatar
jb78L-82
I have had my 360 monospring from VBP on my 78 since 1986! Still perfect today!
Old Mar 5, 2011 | 07:52 PM
kdf1986's Avatar
kdf1986
If you have the offset trailing arms, will a stock monospring work, or is there a modified one for this setup.
kdf
Old Mar 8, 2011 | 10:39 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
kdf
A stock spring will work w/offset arms. It's the rim & tire package a person chooses that determines weather or not the rear spring needs to be shortened or not.
To monoleaf
