Holley Float question - supposed to be liquid inside the float?
Old Apr 13, 2002 | 08:14 PM
Maurice's Avatar
Maurice
Default Holley Float question - supposed to be liquid inside the float?
I have a Holley 4160 carb and I was just looking at the secondary float and I noticed it was filled maybe 1/4 with liquid? I didn't see how it could get in there if it wasn't supposed to be, and I couldn't find a way to get it out without drilling a hole. It looks like it supposed to be there as it looks like there are 4 chambers that the fluid can move around to inside the float. Thanks in advance.
Old Apr 13, 2002 | 08:35 PM
Pete79L82's Avatar
Pete79L82
Default Re: Holley Float question - supposed to be liquid inside the float? (Maurice)
There is not suppose to be any liquid inside of the float. what happens is that over time a small pinhole will develope in the welding and allow fuel to get inside. Time to replace the float.
Old Apr 14, 2002 | 02:16 PM
Maurice's Avatar
Maurice
Default Re: Holley Float question - supposed to be liquid inside the float? (Pete79L82)
Thanks, this carb is killing me!
Old Apr 14, 2002 | 03:11 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
do you have the center hung white plastic float, and secondary plate instead of a metering body you need a nitrophyl float #116-3. if you have a metering body with removable jets you can use brass float # 116-2. if you have the side hung float you need part # 116-4 :chevy
Old Apr 15, 2002 | 06:23 PM
Maurice's Avatar
Maurice
Default Re: Holley Float question - supposed to be liquid inside the float? (clem zahrobsky)
Thank you for the info. What would be the result of having the liquid in the float? What would I expect to be happening performance wise?
Old Apr 15, 2002 | 06:30 PM
Kingt's Avatar
Kingt
The float should not have any fluid in it. If the float gets too much it won't "float". It will cause you fuel level to be too high leading to flooding, surging, and all sorts of carb woes. Replace it!
Old Apr 16, 2002 | 11:37 AM
fontking1a's Avatar
fontking1a
The float is supposed to "float". It is designed that way to keep your car running consistently. The amount of fuel in the "float bowl" directly affects performance. Too much fuel, runs rich....too little, runs lean. The needle seat assembly is the "door" that the float controls. There has to be just the right amount of fuel going (seeping) through the door for your car to run properly. It is a critical part of the carb. If the float leaks, it doesn't work the way it was enginnered to work so....toss it. Don't try to fix it....buy another.
To Holley Float question - supposed to be liquid inside the float?
