Changing Belts 1971
Old Mar 3, 2011 | 12:03 PM
jbakyy's Avatar
jbakyy
Default Changing Belts 1971
hello,
are changing the 2 engine belts on 1971 simple process. any tips or suggestions are appreciated.
thank you,
greg
Old Mar 3, 2011 | 12:26 PM
oldsarge's Avatar
oldsarge
Not too tuff of a job. You should get yourself a GM service manual, for your car. It will give you all kinds of info on most tasks you want to do.
Old Mar 3, 2011 | 12:38 PM
Mashman's Avatar
Mashman
It's very simple. But something to remember is that the belt routing (and therefore the belt size used) may be different depending on what accessories you have.
So to make sure I get the right one, I always cut off the old one, and take it with me when I get the new belt. That way, you are sure to get the correct belt.
Just loosen the adjusting bolt. Loop the belt over the fan, and onto the pulleys. Pull, and tighten the adjusting bolt.
Old Mar 3, 2011 | 01:54 PM
Alan 71's Avatar
Alan 71
Hi Greg,
As Sarge and mash have said it's not too big a job.
Depending on your car's options you may have a short belt that only runs between 2 pulleys, the water-pump pulley and the pulley on the harmonic balancer.
If so there's nothing to loosen like the alternator to get the slack needed to get the belt off. I've always had to loosen the fan clutch and then the pulley on the water-pump; tip the pulley enough to get the belt on, and then tighten the pulley bolts back on the water-pump.
The alternator belt is more straight forward to replace.
Good Luck!
Regards,
Alan
You can just see the sort belt in this picture...it's in the groove closest to the block.
Old Mar 3, 2011 | 02:03 PM
7T1vette's Avatar
7T1vette
The belt that does NOT have any adjustment needs to be installed as Alan_71 described. Loosen the fan-to-waterpump nuts, loop new belt over the fan and onto the [tilted] pulley, then re-tighten those nuts. If you were provided with the correct belt, that should do the 'trick'.
Old Mar 4, 2011 | 12:24 PM
jbakyy's Avatar
jbakyy
thanks everyone!
To Changing Belts 1971
