electrical failure, 1979 Corvette
Old Mar 10, 2011 | 03:52 PM
sivb@flash.net's Avatar
sivb@flash.net
4th Gear
Default electrical failure, 1979 Corvette
I seem to have lost all power to my horn, dash lights, instruments, heater blower, courtesy lights, etc. I've checked all the fuses and they are good. The only other thing I can think of is the 30 amp Power Assy Circuit Breaker. Has anyone else experienced this and, if so, what did you do to fixit?
Doug
Old Mar 10, 2011 | 04:36 PM
speedreed8's Avatar
speedreed8
check the fusible links at the starter. it supplies power to the fuse box.
there is also multiple wire black connector by the a/c box just above the trans dipstick tube. check it for corrosion. has some red wires (+).
