Headlamp Replacement
Old Mar 9, 2011 | 07:44 AM
MrJlr's Avatar
MrJlr
Default Headlamp Replacement
I bought Halogen headlamps for my '74.
What all is involved in changing them ? I would assume it's pretty straight forward - but being a Corvette...
Do I need to pull the engine ?
A full body-off ?
Some kind of rain-dance ???
How many beers ?
No..seriously, some pics or tips anyone ?
Otherwise I'll just crack a beer and have at it...
Old Mar 9, 2011 | 09:36 AM
Legacy Stables's Avatar
Legacy Stables
for head lamp conversion the most you will have to do is modify the bezels to get the lamps in. just hook up and enjoy the night.
Old Mar 9, 2011 | 12:57 PM
MrJlr's Avatar
MrJlr
No one else ?
Do I remove the front clip ?
Old Mar 9, 2011 | 03:55 PM
kdf1986's Avatar
kdf1986
I dont know about the halogen light connection, but for regular light replacement it is pretty easy and straight forward.
1. The lights need to be in the up position.
2. Remove the shield that goes around the headlights. I think there are 4 small screws for this.
3. There is a chrome/stainless ring that goes around each light. This is held in place with very small screws. They may be rusted in place. I stripped out two of these trying to get the bezels off.
4. After removing the chrome bezels plan on spending another 30 minutes to clean and repolish them. After all they are out of the car and you wouldnt want to put back dirty parts.
5. Pull out the lights and disconnect from the wiring harness.
6. Reinstall the lights, bezel and shield.
7. For the light alignment, I think you can get to the adjustment screws with the shield in place. If I can remember correctly the shield will have small slots where the alignment screws are.
kdf
Old Mar 9, 2011 | 04:16 PM
MrJlr's Avatar
MrJlr
kdf
Thank you ! THAT'S what I was looking for...!
Old Mar 9, 2011 | 04:21 PM
Alan 71's Avatar
Alan 71
Hi jlr,
If you follow kdf's directions this is what you'll see when you take the shield (headlight bezel) off.
You can see the stainless steel rings, and the screws that hold it and the lamps in place.
Not a difficult job at all.
Regards,
Alan
Old Mar 9, 2011 | 04:29 PM
MrJlr's Avatar
MrJlr
Originally Posted by Alan 71
Hi jlr,
Regards,
Alan
Sweet.....simple. I was worried I might have to jump through a lot of hoops....
(Note my sarcastic thoughts from above...!)
Thanks guys...looks like a 2 beer job !
Old Mar 9, 2011 | 04:41 PM
keeks2915's Avatar
keeks2915
Hi jlr,
Regards,
Alan
Will those bolts on the side of the housing adjust how the door sits when the headlight doors are down?
My passenger side headlight sits slightly below flush when closed and I need to adjust it up
Old Mar 9, 2011 | 05:27 PM
Alan 71's Avatar
Alan 71
Hi K,
The 'stop' for the closed position is a 'bolt', it's hex headed, with a hex shank, and about 2 inches long.
It mounts in-between the 4 springs. You can see the shank end of it in the very center of this picture. It's just above the micro switch.
There are various things that influence how the door fits when closed, but this is the first thing I'd check.
Good Luck!
Regards,
Alan
Old Mar 9, 2011 | 05:31 PM
MrJlr's Avatar
MrJlr
Hi K,
Good Luck!
Regards,
Alan
Wow....you really detailed your headlight assemblies ! Looks awesome....kinda doubt my is gonna look like that !
Old Mar 9, 2011 | 06:25 PM
Alan 71's Avatar
Alan 71
Hi jlr,
Yours can look like those.
All original parts.
Some Simple Green, a bit of time with a wire wheel, some paint and some plating.
Honest!
Regards,
Alan
Old Mar 9, 2011 | 06:41 PM
72LS1Vette's Avatar
72LS1Vette
4 headlights = 4 beers.
Rick B.
Old Mar 9, 2011 | 08:19 PM
keeks2915's Avatar
keeks2915
Hi K,
Good Luck!
Regards,
Alan
Thanks as always! You guys are the best.
Old Mar 9, 2011 | 08:53 PM
'75's Avatar
'75
One more thing to remember. Don't mix up the stainless rings, I believe they are all different and won't interchange.
Old Mar 9, 2011 | 08:58 PM
kdf1986's Avatar
kdf1986
Im not sure if they wont interchange, but I know the tabs are not symmetrical and they seem to only line up one way. Maybe the left and right side will not interchange. Now I can see that happening because they may be mirror images of each other on tab position.
kdf
Old Mar 9, 2011 | 11:24 PM
7T1vette's Avatar
7T1vette
Is the current drawn by the halogen bulbs similar to that of the regular bulbs? If so, there is no concern about wiring/fuses. If the halogens draw much more current, there is a need to evaluate and/or upgrade the wiring and fuse (or fusible-link) before 'doing the deed'.
Old Mar 10, 2011 | 06:37 AM
MrJlr's Avatar
MrJlr
I was told they draw less...???
Old Mar 10, 2011 | 04:44 PM
Alan 71's Avatar
Alan 71
Hi,
The black 'cups' are all different. Each has a letter embossed in it. They need to be returned to the right location.
Looking from the front of the car they are C B D A.
Regards,
Alan
Old Mar 10, 2011 | 05:24 PM
MrJlr's Avatar
MrJlr
Hi,
The black 'cups' are all different. Each has a letter embossed in it. Thy need to be returned to the right location.
Regards,
Alan
Wow...good to know....I'll watch for that !
To Headlamp Replacement
