Wiper door timing
Old Mar 19, 2011 | 10:35 AM
dmg1029's Avatar
dmg1029
Default Wiper door timing
Folks,
I have a 69 coupe BB, 4 speed car. I am having problems with the wiper door closing before the wipers are fully parked. I have to manually (using the **** under steering wheel) open and close the wiper door so it won't close on the wiper arms when I turn them off. The come on just fine. I did notice a air connection point with 3 vacuum hoses (2 of which are connected and one is missing) under the door to the right of the passangers wiper arm. I'm trying to understand how the timing of the wiper door works as related to the wiper parking.
Thanks much.
Old Mar 19, 2011 | 10:58 AM
dmg1029's Avatar
dmg1029
I think (thru reading other posts, etc) that I need a new wiper interlock (or parking) valve. I ordered one from CC for $25 plus shipping. Looking at Dr Rebuilds pic, the black hose coming from this valve just enters the firewall and remains open right?
See this pic on link
http://www.docrebuild.com/dr-r-web/DROOPY2.HTML
Does that make sense?
Old Mar 19, 2011 | 03:01 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
You got it. The one hose just vents thru the firewall grommet with the red and white stripe hoses. You may have to slot the mounting holes in that valve base to allow for adjustment. When the wipers are fully parked against the stop at the base of the windshield, the valve should be fully actuated.
Old Mar 19, 2011 | 05:18 PM
Chuck72's Avatar
Chuck72
The door closes as a result of the wiper arm contacting the vacuum control. The vacuum control is slotted, so, it sounds like you need to mark the position of the valve, loosen the two bolts holding the valve, squirt some WD 40 on the bolts, and slide it down some. Try about 1/4", to start. When the wiper motor is in the park cycle, the only way you can get the motor to stop, is to disconnect the battery, if the arm catches on the closing door.
Chas
Old Mar 19, 2011 | 07:49 PM
dmg1029's Avatar
dmg1029
Thanks folks. I see from looking at the new valve, that the valve installed is missing the part that the passanger wiper contacts to allow the wiper door to close.
I've ordered a new valve and will also replace some hoses while I'm at it.
Old Mar 19, 2011 | 09:47 PM
7T1vette's Avatar
7T1vette
That interlock valve MAY be the cause of your problem. BUT, if the (3) hoses on that valve are not installed in the proper position, that can cause the same symptoms, even if the valve/switch is good! One of the three hoses is just a vent hose and runs just into the engine compartment and is severed, going to open air. That is how it is supposed to be. But, all three hoses need to be on the proper nipples. If you need to know 'which is which', ask on a further post. (I'd tell you now...but I'd have to drop the car on the lift and look!.)
Old Mar 20, 2011 | 12:32 AM
Rontech's Avatar
Rontech
Default wiper door
Originally Posted by dmg1029
Folks,
Thanks much.
Hi.
Willcox has a great "repair and installation" section. Check it out
http://willcoxcorvette.com/instructi...function_2.pdf
http://willcoxcorvette.com/instructi...ted_080509.pdf
Ron
Old Apr 16, 2011 | 11:00 PM
dmg1029's Avatar
dmg1029
Folks.. I have the vacuum switch (or valve) that goes under the pass side wiper and controls the timing of when the wiper door closes. Now, what is the best way to replace it? Looks like there are 2 small bolts holding it on, but hard to get to. Do I remove the cowl or use a swivel socket and long extension? I hope I don't have to remove the wiper door??
Thanks for the help..
Old Apr 17, 2011 | 01:15 AM
Rontech's Avatar
Rontech
dmg1029,
HI, I believe you can just remove the Grill panel just forward of the Wiper Door. It has Eight screws holding it in place. The valve is just below the grill section. Did you read the Willcox repair section from the links above? They will help quite a bit.
Ron
Old Apr 17, 2011 | 09:32 AM
dmg1029's Avatar
dmg1029
Thanks so much Ron. I did read the links and saved them, however they did not have the replacement directions. I appreciate the help.
PS I now have a chassis service manual also.
Old Apr 17, 2011 | 06:04 PM
dmg1029's Avatar
dmg1029
Update.. Well, removing the cowl (easy...) worked fine. Once the vacuum switch was replaced, the wiper to wiper door timing worked perfect! I even replaced the wiper blades!
Thanks to all for the help!
I know you folks like pics, so here are a few since it's our first nice sunny day in a while... Enjoy!
Old Apr 18, 2011 | 02:01 AM
Rontech's Avatar
Rontech
dmg1029
Well done! We always like those Thanks!!! Your car looks really nice. You must take great care of the car. Thanks for the pictures. You can always ask the Forum for help and get an answer.
Thanks Ron
To Wiper door timing
