Help!!
Old Mar 22, 2011 | 03:18 AM
Colin Paris's Avatar
Colin Paris
Cruising
Default Help!!
have recently developed a problem which has myself and local experts a little perplexed
after giving the car 75' a little burst from cold it has developed a serious hesitation especialy on cross over from idle to pump jets.
Had timing checked, pump adjustments checked ,new distrubutor cap ,leads.plugs,coil, and everything seems okay
Am now considering a new distrubutor but am told the electric ignition either works or doesnt so this should not be the problem? is this so ??
I am, and have been running for the past three years, holly 650 double pumper and open manifold but nothing changed there and as this fault started instantly cant see this being a problem !
would suggest it is the original distrubutor or a like for like replacement
any ideas or suggestions would be appreciated
Old Mar 22, 2011 | 07:45 AM
joewill's Avatar
joewill
maybe I am old or something but I am confused by some of the terms here.
what does a little burst from cold mean?
what does cross over from idle to pump jets mean?
how are pump adjustments checked?
what is an open manifold?
Old Mar 22, 2011 | 08:51 AM
929nitro's Avatar
929nitro
My 75 would hesitate and it was partially due to a bad vacumn advance unit on the HEI distributor.
Old Mar 22, 2011 | 09:40 AM
7T1vette's Avatar
7T1vette
Sounds like a carb/choke problem to me.
Old Mar 22, 2011 | 02:43 PM
Colin Paris
Cruising
Default help
sorry about my poor descriptions but to explain ( I hope)
start up cold engine and give reasonable throttle through gears ( being Manual) sorry stick shift
secondly attempt to describe the throttle opening from idle to main jet
thirdly, feeler gauge tolerance under pump adjustment lever at stationary but with throttle at fully open
lastly, my best desciption of a slightly raised alluminium manifold which basicaly has just a square opening without internal chambering ( I think!)
Old Mar 22, 2011 | 02:48 PM
Colin Paris
Cruising
Default help
checked that and is working correctly as far as far as I can tell.
Sucking on vacum pipe after disengaging from carb, advance mechanism can be seen to move in distrubuter
Old Mar 22, 2011 | 03:51 PM
firstvett69's Avatar
firstvett69
Default hesitation
Are you saying that when your car is cold and choke is on,you are driving and when you touch the gas it hesitates/stumbles ?. If so 7T1vette has answered your question, and or maybe your accelerator pump is bad, If I am understanding you correctly, just thoughts, good luck.
Old Mar 22, 2011 | 04:26 PM
Les's Avatar
Les
I wouldn't touch the ignition until I know the carb is working properly. As stated by others, make sure the choke is OK and then check/replace the accelerator pumps (both primary and secondary). They should start squirting gas as soon as you see the cams for the pumps come into play. If you're not sure how to do that an alternative is to borrow a working carb and see if that eliminates the problem. Good luck.
Old Mar 22, 2011 | 06:34 PM
Colin Paris
Cruising
Default help
Thanks for the response and advise
currently running without a choke either manual or electric and chock butterfly fixed in open position
on activating primary pump plenty of fuel seems to be present but not tried secondary as I feel the fault is evident too early for the secondary pump to be an issue?
am ignorant as to the workings of the carb internals and wonder could there be a blockage or something seerate from the pump jets?
currently have booked the car in to a local specialist and know he is not in favour of the large carb currently installed but hoped to find a solution rather than be forced into fitting another carb and even another manifold as being suggested at this time
is there a maintenance or breakdown information on areas that I could carry out myself
Old Mar 22, 2011 | 09:46 PM
Les's Avatar
Les
A Google search for Holley carbs will get you a lot of useful info along with some exploded diagrams. If you've been running w/o a choke all along that really shouldn't be your problem.
The link below shows photos at the bottom of the page of what the 650 looks like when off the car and inverted. You can see that the accel. pump diaphragms are located under the end sections of the carb and are inside a cover that's secured by 4 phillips head screws. If you decide to tackle replacing the diaphragms but have never done it before just look carefully as you pull the cover off because there's a spring in there that needs to go back where it came from. The arm that is attached to the cover also needs to go as pictured. The assembly that it contacts needs to be positioned as it's shown in the picture. It rotates during disassembly and you'll need to have it in proper position before tightening the cover back into place. This should all make sense if you disassemble it but if you want to be safe get a buddy with experience to help. It's not really that complicated- probably harder to describe than to do! Here you go-
http://forums.corral.net/forums/5-0-...out-vents.html
Old Mar 22, 2011 | 10:21 PM
Rusty-one-1's Avatar
Rusty-one-1
Did you get a backfire through the carb? Hollys are pretty well known for blowing the power valve inside the carb when this happens
Old Mar 23, 2011 | 02:19 AM
Colin Paris
Cruising
thanks for you help used to taking carbs to bits on motor bikes and mowers etc but never attempted something like this Gulp!!
will take a look at site as suggested thanks guys
Old Mar 23, 2011 | 02:21 AM
Colin Paris
Cruising
Yes there is a good chance this may have happened as It isnt uncommon to get a backfire when starting sometimes
thanks again
Old Mar 24, 2011 | 04:06 PM
Colin Paris
Cruising
Hi all
Have taken the easy option as local deales had a new 600cfm Holley which when fitted cured the problem
will have to look deeper into my old one to see what was wrong but can now do it at leisure with the car on the road
thanks for your posts
Old Mar 24, 2011 | 04:11 PM
Rusty-one-1
Throw a rebuilt kit in it, the kit will come with a new power valve. Then you will have a spare carb ready to go.
To Help!!
