seat angle
Old Mar 22, 2011 | 01:14 PM
manfroni's Avatar
manfroni
Default seat angle
just finished installing '79+ seats in my '78. Any ideas on how to adjust the seat angle? It seems like it is sitting too far back on the rear support of the seat. The frames are new, so no cracks. Can I shim the rear tracks up?
Old Mar 22, 2011 | 02:47 PM
gkull's Avatar
gkull
Yes, you could. But i would try to support as much of the slide track as practical and then just use longer bolts at the back.
My 79 never seemed to have enough head room. So to lower my seat I pulled out the thick insulative lay under the carpet and put in the thinner flame proof sound isolation aluminum mat and short pile fire retardent carpet. I made custom flat iron stock mounts and bolted my seat directly to my floor.
Old Mar 22, 2011 | 05:10 PM
oldsarge's Avatar
oldsarge
They use to make shims for that purpose, so I think you can just shim the rear of the tracks to a point you like.
Old Mar 22, 2011 | 10:03 PM
7T1vette's Avatar
7T1vette
I raised mine 1/2" in back and it made up the angle difference I needed.
Old Mar 23, 2011 | 07:55 AM
ray79's Avatar
ray79
The stock '79 seat frame - driver side only - had a wedge spacer on the front of the track. Have you already removed that?
To seat angle
