Engine won't start
Old Mar 23, 2011 | 03:32 PM
Chris1357's Avatar
Chris1357
7th Gear
Default Engine won't start
Hi all. I have a '73 with stock setup. I have had the car for ~1 year and has ran great with no major issues. On a recent drive I noticed the engine temp was getting high after a short drive(was always solid at 190 even in Pheonix summer) and was apporaching ~220. When parked, i saw that coolant was leaking so tried to pull the hood and the hood cable broke! Fast forward 2 weeks(very busy) and I finally got the hood open. Leak coming from water pump gasket. Started car and put up on ramps(took a few goes to get the car up the ramp with low coolant) and before I started any work on the car, tried to start the car again(forgot to check if water pump was working) however car would not start nor did it sound like the starter would engage(was getting a low clicking noise however sounded like it was coming from driver side). Engine was only on for a few minutes with low coolant. I've checked battery and getting a good 12.3V and all electrics in car functioning. Any ideas? Could I have blown a fuse? Engine seized after short time? Disturbed some wiring during my hood release work?
Old Mar 23, 2011 | 03:51 PM
johnt365's Avatar
johnt365
My first guess is to put a charge on the battery or go have it tested. You need to test the cranking amps if you have a load tester.
Old Mar 23, 2011 | 04:09 PM
firstvett69's Avatar
firstvett69
Default wont start
As in previous post, hook up battery charger. Put charger in start/high position and see if the car will start, the clicking your hearing on the pass side of the car is the starter solenoid. Battery cranking power to low or bad starter solenoid,If your car starts with the charger on the battery, shut it off and charge your battery,if after a day or two it will not start again have the battery tested, if the battery is good you probably have a bad starter/solenoid. Good Luck
Old Mar 23, 2011 | 05:04 PM
Peterbuilt's Avatar
Peterbuilt
Default On the Battery & the frame & at the starter.
You might want to make sure the + & - connections are all clean and tight.
Old Mar 24, 2011 | 12:37 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Clicking sound is usually low battery. Clean the battery terminals and cable ends and the negative ground undereath on the frame. Charge the battery.
Old Mar 24, 2011 | 12:53 PM
jkjazzsax's Avatar
jkjazzsax
Also make sure the clamps to the battery terminals are tight.
Old Mar 24, 2011 | 01:10 PM
Vetteman75's Avatar
Vetteman75
Cruising
Default how to get the hood open
Chris sorry to jump off topic, but how did you get the hood open?
I have a 75 Vette and only the passenger side will pop, anyone have any idea how to get the hood open and how to adjust it?
Old Mar 24, 2011 | 01:26 PM
Chris1357's Avatar
Chris1357
7th Gear
Default To get hood open
Thanks all for your suggestions. I will give it a go at the weekend and let you know if I make any progress.
On the stuck hood, I tried going under the car and thats how I opened the passenger side however could not access the drivers side. So I used the method described in many posts here by popping out the small plastic blank off in the wiper well area and used a long screw driver to find the latch. I have to say it took me a good hour to get it and its a complete pita however the method does work.
Old Mar 24, 2011 | 01:41 PM
Vetteman75's Avatar
Vetteman75
Cruising
Thanks, Chris Ill give it a try!!!
Old Mar 25, 2011 | 12:58 AM
kdf1986's Avatar
kdf1986
When you crawled under the car to open the hood from the passenger side, where you near the starter area. There are wires from that which go back to the battery and the coil. You may have broken one of those wires which could lead to your starting/charging problems.
kdf
Old Mar 26, 2011 | 09:08 AM
Vetteman75's Avatar
Vetteman75
Cruising
Thanks for all the info, however still cant get it. I pulled the cable under the hood, and everything else and still drivers side wont pop!!!
To Engine won't start
