Coolant Temp Indication
Old Mar 26, 2011 | 07:29 AM
72-454's Avatar
72-454
Default Coolant Temp Indication
Two days ago was driving my 82 the first time after one and a half year. All indications were in the "green". Today the coolant temp indication was dead. I have an EBL installed and can see the water temperature there. It is responding to the sensor on the right front of the intake. Before I change the gauge I have a question: Are there some other connectors going to the gauge which I should check first? And is there a second sensor for the gauge? There are two more in the block, one should be the knock sensor.
Old Mar 26, 2011 | 08:06 AM
...Roger...'s Avatar
...Roger...
Check the connection at the sensor in the drivers side head between spark plugs #1 and #3.
Green wire
Old Mar 26, 2011 | 03:23 PM
72-454's Avatar
72-454
There is a sensor at this location in the head with one green wire on it. Is it the sensor for the gauge, is the other one only for the computer?
Old Mar 26, 2011 | 04:16 PM
...Roger...
Yes
To Coolant Temp Indication
