need help with console instalation
Old Mar 26, 2011 | 10:59 PM
forman's Avatar
forman
Default need help with console instalation
I am about to loose my mind I cant get the two screws on the bottom of the gauge cluster that hook on to the center console any input would be helpful thanks
Old Mar 26, 2011 | 11:05 PM
BHRIG's Avatar
BHRIG
My 77 has a small screw at both the left and right side of the gauge cluster..
you have to remove the side panels of the center console to access these screws..
you have to look UP from the bottom of the cluster to locate the screws..
Hope this helps.......
Old Mar 26, 2011 | 11:43 PM
1972vettman's Avatar
1972vettman
Are they screws or nuts on the studs at the bottom of Gauge cluster? My 72 has 2 nuts that attach cluster to center console, for me i removed the face plate and heater control panel to access. Took a nut driver, broke off the handle, it was just the right length to loosen the nuts. Hope this helps.....good luck.
Old Mar 26, 2011 | 11:51 PM
forman's Avatar
forman
I need to get them on ,,the cars a 70 and they are nuts nut screws thanks ..I think I might be able to loosen the whole cluster and then attach it to the bottom
Old Mar 27, 2011 | 01:18 AM
flaco1801's Avatar
flaco1801
i never bothered to use them...the guage cluster aint going nowhere....if you ever wanna get the gauges out you have to get to those 2 nuts....
Old Mar 27, 2011 | 01:30 AM
7T1vette's Avatar
7T1vette
Take the little side covers off the front ends of the tranny tunnel. You may have to use a flex-driver (like used to adjust carb idle jets) with a 7/16" socket on the end to get them started. Then use a small 1/4" drive ratchet to tighten them--not too much...just snug.
I think some tranny tunnels are made with slots in that front tunnel brace, so that you can just start the nuts, then slide the tunnel in place [and over those nuts], then snug them down.
Old Mar 27, 2011 | 10:42 AM
forman's Avatar
forman
I cant get them I have tryed for hours I am just gunna leave them off I have a manual a chiltons and a chevy book and it wont tell you how its done ,, I am gonna advertise on craiglist for a midget with tiny fingers
Old Mar 27, 2011 | 10:51 AM
flaco1801's Avatar
flaco1801
if you ever have to change out a guage you wil be happy...
Old Mar 27, 2011 | 01:39 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I went to the local hardware and bought 2 nuts each about 1" long. I don't know what they are supposed to be used for but the extra length let me start them on the posts, slide then into the slots on the console and finish tightening them with an open end wrench. This has to be one of those things they pre-assembled at the factory and installed as a single unit.
Old Mar 27, 2011 | 05:08 PM
20mercury's Avatar
20mercury
Agree, I leave them off.
These two little nuts are from h**l for sure and should be used to train design engineers about making accessible and maintainable vehicles!
Old Mar 27, 2011 | 05:17 PM
glackore's Avatar
glackore
7T1vette is right. I just did the same with mine. I've got fat fingers but it can be done. Good luck!
Old Mar 27, 2011 | 05:21 PM
imariver's Avatar
imariver
Raphiki, thoses nuts are called coupling nuts, I used these when I did some repair work on my console. I didn't have any problems putting the nuts back on and the extra length lets you get a wrench in there with no problem........... or at least I didn't have any trouble getting them on.
Old Mar 27, 2011 | 05:48 PM
Raphiki's Avatar
Raphiki
Coupling Nuts! That's what they were.
Old Mar 27, 2011 | 06:04 PM
oldboat's Avatar
oldboat
Raphiki,
you are a genius. i am definitely going to change to your method. those nuts are hell.
Old Mar 27, 2011 | 09:13 PM
keeks2915's Avatar
keeks2915
Be careful when ordering a midget with tiny fingers........... You don't want any misunderstandings.........
Old Mar 27, 2011 | 09:43 PM
noonie's Avatar
noonie
Put the nuts on the cluster first, then install.
Old Mar 27, 2011 | 09:59 PM
forman's Avatar
forman
I tried to put them on the console first but they would not clear the lip .. i will go to the fastener store tomorrow thanks
To need help with console instalation
