Compression test, warm or cold
Old Mar 27, 2011 | 09:06 AM
pwsusi's Avatar
pwsusi
Default Compression test, warm or cold
I'm planning on doing a compression test on my '71. From what i've read you're supposed to do it with the engine warmed up to operating temperature. The problem is it looks like it's going to be a nightmare removing all the spark plugs as they're especially tough to get to on the driver's side. I'll need to let the car sit for a little while to let the manifolds cool off somewhat so i don't burn my hands...then add probably an hour on top of that to get all the plugs out. How inaccurate will the compression test be if i do this with a cold engine? Also, any tricks to getting the plugs out quicker? I'm thinking of doing the passenger side from the top and maybe try driver's side from underneath.
Paul
Old Mar 27, 2011 | 09:48 AM
wnmech's Avatar
wnmech
I was taught to get the most accurate compression check was to do it with the engine warm and all the spark plugs removed and the throttle wide open.
Old Mar 27, 2011 | 10:02 AM
Chromie69's Avatar
Chromie69
These old cars are tough to remove the plugs..what I would suggest before you warm up the car is remove the shielding and anything that is in the way..loosen all the plugs to make sure they will come out easy..put them back in not so tight and do the warm up..make sure you disconnect the fuel and spark before you do the test..a leak down may be easier to do and actually would be the next move if anything comes up off with the compression test.
Old Mar 27, 2011 | 11:02 AM
7T1vette's Avatar
7T1vette
Other than having the oil be thicker because of the lower temperature, I fail to see what difference the engine temp makes to a compression test. It may affect a 'leak down' test some, as it will take more time for compressed air to force through some colder oil in the rings, but on a compression test? Someone else will have to explain to me what difference it makes.
Old Mar 27, 2011 | 11:42 AM
terry82's Avatar
terry82
on my 82 .take out the front both sides 2 plugs from the top .the back two plugs from the bottom.
Old Mar 27, 2011 | 11:54 AM
Chromie69's Avatar
Chromie69
7T1 I figured that's the way he wanted to do it so I would give him suggestions on how to without getting burned by a manifold..I never cared either way myself either.
Old Mar 27, 2011 | 03:30 PM
Les's Avatar
Les
Every mechanic or engine builder I've ever talked to has said to warm up the engine first. From what I recall it's to get oil hot but also to heat up the internals to get optimum ring seal and therefore most accurate results. Just do the best you can to pull the plugs quickly and use gloves to prevent burning yourself if you need to.
Old Mar 27, 2011 | 04:34 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
If you want an accurate PSI rating then warm it up first, not sure it makes much difference.
I go it cold:
1) So I don't burn a hole through my gloves and more importantly...
2) The reason you are doing the test in the first place, you are looking for a cylinder that is not making the same pressure as the rest and you feel it might be a bad valve or piston,
You aren't ( in most cases ) looking
looking for what the PSI is in a certain cylinder you are checking to see if they are all the same or within about 10% of each other whether it's got 170psi or 230psi as long as they are all within 10% of each other
*This goes on all my posts: Please report back to those who helped you the final outcome of your initial post
To Compression test, warm or cold
