71 TH400 Modulator O-Ring?
Old Mar 27, 2011 | 11:29 AM
dprinter1's Avatar
dprinter1
Default 71 TH400 Modulator O-Ring?
My modulator doesn't seat all the way to tranny casing, and is leaking. The body is still off of the chassis so everything is acessable. I took the modulator out when I cleaned the tranny, but I don't recall an O-Ring. I read many of the threads in the search and everyone keeps reffering to the "Modulator O-ring". Is there supposed to be an O-ring around the neck of the modulator. If so can someone please post a pic.?
Thanks folks,
Dean
Old Mar 27, 2011 | 12:14 PM
C3 Stroker's Avatar
C3 Stroker
See the pics of modulators in this link.....the o-ring is on the neck going into the trans;
http://www.thefind.com/cars/info-vacuum-modulator
Old Mar 27, 2011 | 01:27 PM
dprinter1's Avatar
dprinter1
Thanks C3 Stroker, that's just what I needed. I found one that works, should stop the leak, but there is still a space between the tranny body and the flange of the modulator, about 1/8"
By the way.....I grew up in Youngstown/Hubbard.
Dean
Old Mar 27, 2011 | 04:02 PM
7T1vette's Avatar
7T1vette
The retainer strap should pull the modulator completely down to the tranny surface when the bolt is installed. If it doesn't, there is something amiss. Are you sure the modulator pin is engaging with the modulator when you install it?
Old Mar 27, 2011 | 07:16 PM
dprinter1's Avatar
dprinter1
No....I'm not sure, the whole thing is rather baffeling to me. See if you can tell anything about this pic.
Old Mar 28, 2011 | 05:50 AM
dprinter1's Avatar
dprinter1
This is what my modulator looks like, is it even the correct type for this tranny?
Old Mar 28, 2011 | 09:43 AM
7T1vette's Avatar
7T1vette
That looks similar to the original unit. The factory one was painted black, I believe, and the dimensions look to be a bit different...but it's very close. The important aspects are that it doesn't leak and it operates like it is supposed to.
If the unit now seals [since you've installed the O-ring and the tranny shifts correctly at very light throttle and also WOT, then it is doing what it is supposed to do.
UPDATE: I did a web search and that modulator is for Cadillacs up to 1977. It may be a bit different dimensionally, but if it works OK, so what....
Further UPDATE: The FRAM #2329 unit is [apparently] a correct replacement for the THM 400 transmission. It is available at Amazon.com for less than $20.
Old Mar 28, 2011 | 10:29 PM
dprinter1's Avatar
dprinter1
Thanks for all the information, but the picture I uploaded was only meant to depict what my modulator "looks like".
My problem is that mine is not seating all the way back to the trans casing, and i cannot figure out why. The car is not driveable, as the body is not yet back on the frame.
Any suggestions on how to get this modulator seated will be appreciated.
Dean
Old Mar 29, 2011 | 12:20 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
It looks like you have it installed correctly with the tabs pointing the right way. The bolt is supposed to be a real short one...any chance it's bottoming out in the case before pulling the clamp plate down all the way?
JIM
Old Mar 29, 2011 | 06:46 AM
dprinter1's Avatar
dprinter1
JIM
No, the bolt is fine, I can't make it seat by pushing on it. Someone posted about the Modulator pin being enguaged, I'm not sure what that means, I don't see anything that enguages?
Thanks, Jim
Dean
Old Mar 29, 2011 | 07:14 AM
JimT's Avatar
JimT
The end of the modulator that fits into the tranny has a hole. Inside the tranny, I believe, is a pin, or plunger that is operated by the modulator. Look inside the tranny to see if the pin is centered so that the modulator slides over it. I have a '72 with a TH400, and your modulator looks different than mine. Mine only has one vacuum hose port, and you definitely need an o-ring.
Old Mar 29, 2011 | 10:49 AM
7T1vette's Avatar
7T1vette
JimT... That modulator only has one vacuum port, also. The other "thing" on the end is the adjustment screw for fine-tuning of the shift speeds.
BTW, I've been looking for a vacuum modulator that has the same/similar external design as the original unit. After seeing the pic and model numbers of this one, I've ordered one from Amazon. Thanks for the info!
Also, if the tranny shifts OK [early shifts around 2000 rpm at light throttle setting; later shifts around 5000 rpm for WOT shifts], then it is working as expected. If it doesn't leak since you put on the O-ring, drive away...all is good.
Old Mar 30, 2011 | 10:14 PM
dprinter1's Avatar
dprinter1
Well....I'm going to let this one rest and move on to to other areas of the trans that are leaking. I'll top it off with fluid afterward and see if it leaks while sitting there. I am still wondering why I didn't replace all these O-rings while I had it on the bench
Thanks for all suggestions,
Dean
Old Mar 30, 2011 | 11:39 PM
7T1vette's Avatar
7T1vette
Feedback for those who are interested: The Fram 2329 modulator I ordered from Amazon was delivered today... Bad news...same unit that you get as a replacement for the original modulator. It looks nothing like the original unit. Nice try, I guess.
To 71 TH400 Modulator O-Ring?
