1970 base engine pistons
Old Mar 28, 2011 | 02:09 AM
Oldguard 7's Avatar
Oldguard 7
Default 1970 base engine pistons
Can anyone post pics of the pistons used in the 70 and 71 base engine?
Old Mar 28, 2011 | 10:17 AM
7T1vette's Avatar
7T1vette
The '70 pistons just have some 'eyebrow' reliefs for the valves and the '71 has 'dished' pistons to lower the compression ratio. Sorry, don't have pics...
Old Mar 28, 2011 | 06:46 PM
Duke94's Avatar
Duke94
Here's one from my base 270 HP 71'. Do you need more than this view?
Gary
Old Mar 28, 2011 | 10:36 PM
Oldguard 7's Avatar
Oldguard 7
Thanks, is this also the piston used on the 70 base.? The reason Im asking is because in the GM specs manual for the 70 describes the piston head type as flat notched and in the 71 manual it is described as sump. I guess they mean the recess on the piston head as they intergrate with the valve reliefs
Old Mar 28, 2011 | 10:58 PM
Solid LT1's Avatar
Solid LT1
Valve reliefs will be similar but no dish in 1970 base 350 piston. The flat top and smaller combustion chamber give the 70 the 300HP it really seems to have.
To 1970 base engine pistons
