Differential case worn at seal
Old Mar 28, 2011 | 11:03 PM
Korevette's Avatar
Korevette
Default Differential case worn at seal
My left side yoke had worn to the point the c-clip was gone and it wore into the side of the differential case.
What do I have for options? Has anyone repaired these cases?
Dano,
Old Mar 28, 2011 | 11:29 PM
wombvette's Avatar
wombvette
Dano,
Most of the time the seal will stay in ok, and it will cause no problem.
Old Mar 28, 2011 | 11:36 PM
Korevette's Avatar
Korevette
Thanks for the reply Wombvette, it has ground down to the point there is about only .250" of material left. I cant tap the seal in to hold. Any solutions?
Dano,
Old Mar 29, 2011 | 12:02 AM
wombvette's Avatar
wombvette
Dano,
Wow, A bad one.
Some good cleaning and epoxy, short of replacing it.
Old Mar 29, 2011 | 12:41 AM
Gale Banks 80''s Avatar
Gale Banks 80'
If the Yoke wore that much on the inside to allow it to wear that much on the outside I'd say that the Bearings have probably reached there share of Metal fillings to.
Old Mar 30, 2011 | 01:10 AM
Korevette's Avatar
Korevette
Thanks for the replies. I have ordered all new bearings, seals and ready to go but I am concerned about the seal not being able to "seat".
The epoxy has merit. Has there been any experience out there with a machined steel insert.
Dano,
To Differential case worn at seal
