C3 hood pins
Old Apr 8, 2011 | 10:06 PM
Grumpy 427's Avatar
Grumpy 427
Default C3 hood pins
Has anybody done a set of hood pins on an 80 Corvette? not sure if i should use/ modify the original brackets or fab new ones?
Old Apr 9, 2011 | 01:30 AM
Grumpy 427's Avatar
Grumpy 427
Going to be a long day of cardboard templates tomorrow.
Old Apr 9, 2011 | 03:09 AM
rcread's Avatar
rcread
Measure twice, drill once.
Old Apr 9, 2011 | 02:20 PM
Grumpy 427's Avatar
Grumpy 427
I cant believe that nobody has put a set of hood pins on an 80 vette? I feel like a pioneer.
Old Apr 9, 2011 | 04:41 PM
elealusaf's Avatar
elealusaf
http://forums.corvetteforum.com/c3-g...post-pics.html
http://forums.corvetteforum.com/c3-g...hood-pins.html
http://forums.corvetteforum.com/c3-g...and-why-3.html
http://forums.corvetteforum.com/c3-g...-question.html
try these out for pics and ideas...
Old Apr 9, 2011 | 06:00 PM
redman76's Avatar
redman76
St. Jude Donor '09
I know you are frustrated with the stock setup. I was going to do the same but never liked the look of the offset pins. There are some pretty neat setups available though. Which ones are you going with? Post pics when you are done.
Old Apr 9, 2011 | 08:16 PM
Grumpy 427's Avatar
Grumpy 427
Well it looks like they will be even. The 2" square tubing gives you some options. I have to work tomorrow, but will post some pics as soon as i can.
Old Apr 9, 2011 | 08:34 PM
Grumpy 427's Avatar
Grumpy 427
One will be in the thick pad area and one just above it.
2" square tubing.
Th top holes are there so i can get a socket through to tighten the bolts. There is room for the pin.
Old Apr 9, 2011 | 10:31 PM
mrvette's Avatar
mrvette
Eh, put hinges in the back where the belong.....and do what is on some pix on one site or another below....done long time ago, and hood pins through the stock front hinges....
hinges I used off a Lumina mini van...
junkyard hunting....pleasant day, sunshine, and quiet....
Old Apr 10, 2011 | 01:45 AM
mauiwilly's Avatar
mauiwilly
Just have to ask "WHY" put hood pins on a vette hood ??
Old Apr 10, 2011 | 03:09 AM
Clubby99's Avatar
Clubby99
Don't like the look. Hood pins have a function on a race car. No purpose on your car.
Old Apr 10, 2011 | 07:46 AM
SH-60B's Avatar
SH-60B
Old Apr 10, 2011 | 09:04 AM
Grumpy 427's Avatar
Grumpy 427
Sorry but after 2 busted CHINA hood latch cables, i am not going to tollerate not being able to get under the hood again.
Old Apr 10, 2011 | 09:44 AM
mrvette's Avatar
mrvette
OH HELL, if that's you only problem, take the stock handle off, and string a coat hanger with a loop of vacuum hose over it inside for a grip to pull on, and loop it through the latch, and down to inside the fender, that way you can open from either location not that you will ever need to....it hangs down further forward and up higher so not to be easily seen....
I did that on my '72 many years ago, tired of messing with the old stock junk....
Old Apr 10, 2011 | 10:23 AM
elealusaf's Avatar
elealusaf
I'm picturing this in my head and this definitley does not sound like it would be anywhere near nice. just my opinion. there are plugs behind each of the hood latches that you have acess to from the wiper cowl area. push those through and put a screwdriver in to pop open hood ... but he wont need to do that bc he is going to do it right with hood pins and it will look nice and professional.... GO on and put hood pins
if you don't like them you can always refiberglass your hood or leave them open and help the engine breathe
Old Apr 10, 2011 | 11:55 AM
Big Block 69's Avatar
Big Block 69
I think the Hood Pins are a great idea. But not everyone does. I don't intend to be stuck again with a busted hood latch cable.
I am stuck between making them even or offset. I have seen them both ways and I really don't have a preference one way or the other.
Please post pictures when yours are done.
Thank-You,
Rick
Old Apr 10, 2011 | 06:10 PM
Grumpy 427's Avatar
Grumpy 427
For sure Rick there will be pictures. Besides, its an 80 vette, its nothing special. Also i have a wiper cowl cover, so your not going to get to those rubber plugs.
To C3 hood pins
Old Apr 11, 2011 | 08:21 PM
Grumpy 427's Avatar
Grumpy 427
Ok i got them drilled today, just the small holes left to do. It was a perfect fit, i cant believe how accurate i got the holes. Just painting the mounting brackets, and have found a way to mount the factory hood bumper springs.
Old Apr 11, 2011 | 08:28 PM
mds3013's Avatar
mds3013
Excellent execution. mike...
Old Apr 11, 2011 | 08:34 PM
Grumpy 427's Avatar
Grumpy 427
Pass side has some metal to go through.
