Vacuum canister help...do I need?
Old Apr 9, 2011 | 08:15 PM
UCVette's Avatar
UCVette
Default Vacuum canister help...do I need?
So I have been replacing my vacuum lines and I have a few questions. First I am having a problem connecting the lines to the canister (hard to get too) which got me thinking...what exactly does that canister do? There are 2 lines that I need to connect, one goes from top of the carb. The other is a small line that runs to the to a y connection which runs to a port. Do I need those lines? Do I need the canister? If so, how can I get to the canister to connect the hoses????
Please help the mechanically impaired.
Old Apr 9, 2011 | 08:43 PM
C6DuffMan's Avatar
C6DuffMan
You need all the lines if you want everything to work as designed. My best guess is the Can is used to supply a consistent source of vacuum. For example, if you were flooring it and turned the lights on, they would probably open really slow, or not at all. The Can can (ha) store vacuum for those situations. I don't think it was meant to hold vacuum indefinitely, especially with the engine off. There's too many sources for slow leaks. I guess if everything was perfect it would hold vacuum forever.
Old Apr 9, 2011 | 08:52 PM
dburgjohn's Avatar
dburgjohn
it is for reserve. the vacuum goes up and down with engine operation so it is a way to store some for those vacuum powered devices so they keep operating at WOT
Old Apr 10, 2011 | 10:08 AM
78IndyPace's Avatar
78IndyPace
'78s do not have a vacuum canister - at least mine doesn't. The vacuum reservoir is a tubular part of the front frame structure and you can see it in front of the hood when open. It has two larger and one smaller port in the top with two large yellow-striped hoses connecting to the headlight relays and one smaller hose connecting to the pull-down switch under the steering column in the cockpit.
I would bet that you are looking at and trying to connect hoses to the fuel vapor canister located under the power brake booster can on the driver's side fender. Connections are to the gas tank and the carb with a "Y" fitting in between connected to the PCV valve. Other C3 years have different canisters and connections. You might find what you need by doing forum searches on vapor canister. If you don't send me a PM with your email address and I'll send you a scan of the vapor canister hose connections diagram in my Assembly Manual.
BTW: Do yourself a favor and get an AIM (or Assembly Information Manual) for your '78. It shows how stuff in you car goes together. Forum vendors and ebay are sources. Especially important for us "mechanically impaired" types. Also consider getting the "Service Manual" for your '78. Found mine on ebay.
Old Apr 10, 2011 | 10:58 AM
UCVette's Avatar
UCVette
I think you are right. I just assumed it was for vacuum. I do need an aim. Is there an east way to take it off tonget tonthe top so I can connect the hoses?
Old Apr 10, 2011 | 11:37 AM
C6DuffMan's Avatar
C6DuffMan
Maybe remove the gill panel and reach up. I've poked around on my 71 and was able to reach them OK. But I haven't actually replaced the hoses.
Old Apr 10, 2011 | 11:58 AM
7t9l82's Avatar
7t9l82
when i changed my intake and Carb i got rid of all that stuff. since we have an abundance of space in there.
Old Apr 10, 2011 | 12:04 PM
Alan 71's Avatar
Alan 71
Hi UCV,
I believe the vacuum canister is used to store enough vacuum to be able to open the wiper door and headlights without starting the engine, at least once.
The vacuum system was sealed well enough that when new, (and now, if the systems in good shape), the car could sit for a week or more without having the headlights 'wink' or the wiper door 'dance' when the car was started.
The easiest access to the canister is from the top. The vapor canister blocks most of the access through the side grill opening.
Good Luck!
Regards,
Alan
Old Apr 10, 2011 | 12:55 PM
7t9l82's Avatar
7t9l82
you don't vent a carburetor into a vacuum canister. he is describing an emissions cannister
Old Apr 10, 2011 | 03:02 PM
Alan 71's Avatar
Alan 71
Hi UCV,
You're right 7t9, I was thinking VACUUM!!!!
Here's some pictures of the vapor canister and hoses. 1 hose from the tank, one large hose to the pvc valve and carb, and 1 hose to the carb.
If you can't make the connections from above you can loosen the three bolts that hold the canister's bracket to the wheel-well so it drops down a bit and then reach through the grill opening.
Since the gas tank is sealed the vapor canister captures the gas fumes and they're routed to the carb.
Good Luck!
Regards,
Alan
Old Apr 10, 2011 | 04:03 PM
dembo's Avatar
dembo
Not to hijack, but if the vapor canistor is removed wouldn't this create fuel odor problems? I'm asking this because the tank is connected to the canistar, but non of the other ports are connected. Would it help if this Gm part http://www.rmsautoparts.com/prodimages/10033125.jpg is connected to the vapor hose at the tank side to prevent odors? Its a one way check valve so the tank is still vented.
Regards
Nick
Old Apr 10, 2011 | 05:16 PM
Alan 71's Avatar
Alan 71
Hi Nick,
I believe your right. I'm not familiar with the part you linked.
The vapor canister and system really isn't any trouble except that the charcoal in some canisters needs to be replaced after all these years.
There's also a flat felt filter under the bottom cap of the canister that's easy to replace.
Regards,
Alan
Old Apr 10, 2011 | 05:48 PM
volition's Avatar
volition
I'm completely emissions exempt in my state. That said, I ended up making my vapor canister functional again.
It's really worth the time and effort just due to the sheer amount of bad smells the thing gets rid of. If you park your car in a garage, having the canister working right prevents it from making everything in there smell like gas.
Even without having to pass emissions, I would still recommend it be put in and made functional.
Old Apr 10, 2011 | 05:50 PM
volition's Avatar
volition
By the way Alan, your engine bay is beyond meticulous. Kudos.
Old Apr 10, 2011 | 06:00 PM
Alan 71's Avatar
Alan 71
Hi V,
Thank very much!
Since not very many horses live there it had to be pretty instead.
Regards,
Alan
Old Apr 10, 2011 | 06:41 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I chucked mine years ago and don't have problem with smell.
Old Apr 10, 2011 | 07:07 PM
Peterbuilt's Avatar
Peterbuilt
Yes Alan's car looks better with every pic!!!
About the vapor canister...you made me look and I see only 2 hoses on my 74, one to the tank & the other "T"s with the pcv. If there is a 3rd connection where on the carb does it go? To ported vacuum?
To Vacuum canister help...do I need?
Old Apr 10, 2011 | 07:16 PM
71scgc's Avatar
71scgc
I'm with Avette4me. Chuck it if you can. I have no more fuel smell than I did before. This doesn't surprise me as the can was nothing but a hollow plastic shell. Plus, you have the benefit of getting rid of those pesky excess lines getting in the way and cluttering everything up.
Old Apr 11, 2011 | 09:33 AM
78IndyPace's Avatar
78IndyPace
Is there an easy way to take it off to get to the top so I can connect the hoses?
It's been a while, but I think I removed the triangular splash shields on the underside immediately behind the wheel well and pulled the canister down through the opening. You'll have to remove the door sill trim strip to get at one of the bolts attaching the shield.
I had a strong fuel smell that was caused by the short hose connecting the canister to the hard line from the fuel tank. It had rotted badly. But the canister and its filter were in good shape, and replacing all the hoses solved the smell problem.
Ditch the can? Don't know. Before you do that, you might try capping off all the hoses to & from the canister for a while and see if you do or don't end up with a fuel smell problem.
Old Apr 11, 2011 | 05:18 PM
Alan 71's Avatar
Alan 71
Hi 71s,
I believe the canister is supposed to be filled with charcoal; not empty.
Regards,
Alan
