Vacuum canister help...do I need?
Old Apr 11, 2011 | 05:29 PM
Alan 71's Avatar
Alan 71
Hi Pete,
On my 71 q-jet the small white striped hose runs from the canister to a port on the body of the carb just above the base plate.
74?
Regards,
Alan
Old Apr 11, 2011 | 07:50 PM
UCVette's Avatar
UCVette
I managed to cut the hose off from the canister. I wonder what would happen if I just left it open and plugged the two hoses from the carb?
Old Jul 4, 2011 | 09:12 AM
3puttbob's Avatar
3puttbob
This is a great thread. I like the pictures Alan. My '78 seems to have a gross vacuum leak someplace and I can almost get the engine to run more towards normal if I pull and block the large vacuum port from the bottom of the carb. It goes to the canister. Is the canister leaking? or just a diaphragm in it? Looks like a bear to get to with that cruise module in the way.
Old Jul 23, 2014 | 09:25 AM
Griff2002's Avatar
Griff2002
Resurrecting an old thread. I would like to remove my canister to check / replace the filter and activated carbon. However it is not clear to me what the best way to remove the canister is as it is quite crowded around it. I have the AIM showing how it bolts to the inner fender, but not sure if I need to remove anything else to make room to extract it. I'm also worried about how hard it will be to bolt it back in. Any tips would be appreciated.
Old Jul 23, 2014 | 02:02 PM
Alan 71's Avatar
Alan 71
Hi G,
If your car is the one in your avatar I think its easiest to remove the lower metal splash shield and also the side egg-crate grill. (Removing the spas shield requires removing the rocker trim in order to have access to 2 of the splash shield bolts.
This will give you good access.
Then find and remove the 3 small hex-headed bolts in the rear of the wheel well that hold the canister's bracket in place.
Drop the whole thing down, take the canister out of the bracket, do your maintenance, put it back in the bracket, and then put it back in place from the bottom.
Not too bad a job!
Regards,
Alan
Splash shield. You can also see the 2 lower bolts that mount the bracket to the wheelwell.
Canister access through side grill opening.
Canister removed, but still in bracket. It's laying on it's side.
Old Jul 23, 2014 | 03:03 PM
7T1vette's Avatar
7T1vette
The fuel vapor canister also acts as the fuel tank VENT for cars having one. Thus, the filler cap for a car with vapor cansiter (hooked up) should be a NON-vented cap. If the canister is removed, the fuel cap needs to be replace with a VENTED cap...or the fuel tank could collapse.
The vapor canister causes NO HARM; it only captures/stores and then dispenses fuel vapors from the tank to the carb (when engine is running). The "carb" hose should go to a 'ported' manifold fitting on the carb; the "PCV" hose should get T-ed to the output of the PCV valve, and then transfer to the front baseplate fitting on your carb; the "Tank" line should run to the fuel separator gizmo on the side of your fuel tank.
Old Jul 23, 2014 | 04:09 PM
Griff2002's Avatar
Griff2002
Alan - thank you. Looks like your approach will save me lots of time and frustration.
7T1 - Thanks for the alert. I do not plan to run the car without the canister. I am just planning to go through my fuel system and see if I can find any areas contributing to a mild fuel odor in the garage on hot Houston days. When I got the car it had a vented cap, and the vapor line from the tank to the canister was not hooked up. I have added a sealed cap and hooked up the vent (and by the way I about crushed my arm trying to reach up to hook it up). There is no pressure or vacuum build up in the tank. I suspect I will ultimately find the odor coming from old tank gaskets but want to start with the canister.
Old Jul 31, 2014 | 12:15 PM
Griff2002's Avatar
Griff2002
So here's what I found.
Diaphragm seems to be in good shape. The PCV port was slightly moist with an engine oil smell. Not sure exactly what the diaphragm does / how it works. I think maybe it shuts off flow through the canister to PCV unless there is high enough vacuum to the carb port (just a guess - probably wrong).
I removed the lower filter below the plastic screen (would have been at the top of the picture since canister is upside down). Not sure if this filter was original. There was additional filter material above the plastic screen (as seen in this picture). It had deteriorated such that when the lower filter was removed, the activated carbon can easily fall out. I replaced the lower filter.
Finally, I smelled the activated charcoal and it has a hydrocarbon smell to it - not sure if it is gasoline or engine oil type of smell (but I have a headache now). Perhaps it is because the car has been sitting a week and the charcoal is doing it's job. I'm thinking I should try and find some charcoal somewhere and replace it.
Would appreciate any of your expertise on how to proceed. Thanks.
Old Jul 31, 2014 | 01:37 PM
C3Hawk's Avatar
C3Hawk
(Assuming we are talking about the gas vapor canister, not the vacuum reservoir here.)
The activatated charcoal is available at any pet store with the fish/ aquarium stuff. Just dump the old stuff and replace it.
Can't remember if the Corvette vendors sell the filters or not. Might need to cut filter paper to shape.
Old Aug 2, 2014 | 11:05 AM
Griff2002's Avatar
Griff2002
I replaced the activated charcoal and was curious whether the old charcoal that smelled of hydrocarbon would easily ignite. I put a lighter to it and it ignited instantly. A couple of spoonfulls burned for several minutes, so it seems there was quite a bit of hydrocarbon on the charcoal. I'm hoping this is a function of the age of the charcoal rather than a problem with the EVAP system.
Old Aug 2, 2014 | 12:23 PM
7t9l82's Avatar
7t9l82
ever heard of a charcoal grill? why wouldn't it burn?
Old Aug 2, 2014 | 01:57 PM
Griff2002's Avatar
Griff2002
It lit instantly and the activated charcoal did not burn. When it finished burning, the material looked just like it did before I started - black granular carbon. There was no ash whatsoever, and the hydrocarbon smell was gone. Maybe over time the activated charcoal loses it's ability to desorb the hydrocarbons.
Old Aug 2, 2014 | 11:36 PM
  #33
7T1vette's Avatar
7T1vette
That little diaphragm at the top of the canister is the valve which initiates the PURGE of collected vapors. And, that diaphragm is triggered by a vacuum signal line connected to a "timed" or "ported" vacuum fitting on the carb. When the carb is at idle, there is no vacuum signal coming from a ported/timed fitting. But, as soon as the throttle plates are cracked, the vacuum in a ported line approaches the vacuum level of "manifold" vacuum.
Thus, at idle, the canister just sits there holding on to any collected vapors. When the throttle is opened, the ported line gains vacuum and the diaphragm switch is actuated. This allows vapors in the canister to transfer into the base of the carb, where it is ingested with the fuel charge.
If the diaphragm switch is not functioning, there are no vapors being purged by that canister.
P.S. You really don't want the diaphragm switch connected to 'manifold' vacuum, as it would negatively affect idle quality.
Old Aug 3, 2014 | 01:32 PM
  #34
Griff2002's Avatar
Griff2002
Thanks - very helpful. I'll double check my vacuum connections, but I think they are correct. Hopefully the issue is just that the charcoal was old and lost it's ability to desorb. My nose thinks the garage smells better, but it's been unseasonably cool in Houston this weekend.
