USA made brake rotors?
Old Oct 18, 2013 | 09:37 AM
Mike Ward's Avatar
Mike Ward
Possibly then the statement should be made that GM never sold front rotors without the hub. As for the rears, dunno.
I have an original print '67 Corvette GM shop manual packed away. I should dig it out to see what instructions/cautions were given when rear wheel bearing assembly work was required. I know one owner who had new rear rotors installed in the late 70s and spent years chasing braking issues till they finally figured out his runout issues.
Old Oct 18, 2013 | 11:30 AM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
Originally Posted by aussiejohn
G'day,
If the calipers are made in Australia (which ALL Corvettes have used since 1983!) then rest assured that they will be of good quality. GM owns General Motors Holden in Australia and the local brake manufacturers have to make their products to the GMH standard. When supplying to GM USA, the quality has to be of at least the same standard as for the local cars.
They'd lose a valuable export contract if they cheaped out.
Regards from Down Under.
aussiejohn
Thanks Aussiejohn! I would never question the quality coming from OZ. I have lots of friends down there. You guys have a patent on fine people for sure.
Dave
