Going for Three...
Old Sep 16, 2013 | 11:32 AM
TedH's Avatar
TedH
Default Going for Three...
My engine is still leaking at rear. Swapped out what turned out to be a warped passenger valve cover for a heavier Chevrolet Performance cover that I had on the shelf and that slowed the leaking at rear of the engine but it still drips.
Going to pull the Transdapt pan and old pan gasket and rear main seal to install:
Milodon oil pan (30701)
Fel-Pro oil pan seal
Fel-Pro Rear Main seal
One of these (or all) should help with the persistent leak I have.
A while I am at it part is a mellings stock volume oil pump with pickup (to suit the roller cam).
I am hopeful I will exorcise this demon once and for all. I will be cleaning the underside of the car once this is resolved. It is covered with oil from the leak.
Old Sep 16, 2013 | 11:48 AM
hugie82's Avatar
hugie82
Did you check the rear of the intake and, distributor ?
Old Sep 16, 2013 | 11:51 AM
hugie82's Avatar
hugie82
If you do end up replacing the rear seal? Don't forget to check the cam plug for leakage. Its rare but does happen.
Old Sep 16, 2013 | 12:00 PM
7T1vette's Avatar
7T1vette
There are 3 oil port plugs on the rear face of the engine block; they surround the cam bearing pocket area. And, they can leak after this many years. Ask me how I know....
Old Sep 16, 2013 | 01:16 PM
TedH's Avatar
TedH
Yes. Several times. Even the oil sender; dry as a bone.
Old Sep 16, 2013 | 01:17 PM
TedH's Avatar
TedH
Holy moly. I'll try to shine a trouble light up into that area when the pan and trans cover are off. Have to pull passenger header to drop the idler arm and pulling starter for good measure so I can get at pan rail bolts without too much cursing
Old Sep 16, 2013 | 06:48 PM
TimAT's Avatar
TimAT
IS your oil pan chrome by any chance? I've seen them (chrome oil pans) not hold a gasket or seal because the chrome was too slick. Roughed them up with some 80 grit paper and no more leak.
Old Sep 17, 2013 | 09:38 AM
1977L48's Avatar
1977L48
distributer gasket, I know mine has a small leak, nothing dripping but enough to look shiny after I clean the engine.
Old Sep 17, 2013 | 11:31 AM
TedH's Avatar
TedH
It is black painted steel. One thing I found strange was that I had to torque the rail bolts down before it would sit on the gasket; there was about a 1/2" gap between the gasket where it sat on the rails and where the pan sat (engine was upside down on the engine stand). I guessed this was due to the fat seal in front or that the two seals have to press into both the timing cover and rear main cap.
Old Sep 17, 2013 | 06:01 PM
DUB's Avatar
DUB
I am concerned about that also. You should not have to pull the pan down to get ti to seal. The pan should have contacted the gaskets with almost no gap. Possible oil pump pick up screen interference...or too low...contacting the bottom of the pan.
If you have not tried it...I use the UV dye to isolate any leaks so I can see what it going on with a black light. A little dye goes a long way when you have clean oil.
DUB
Old Sep 17, 2013 | 06:06 PM
TimAT's Avatar
TimAT
DUB
The pan should set on the gasket all the way around, with it just a little bit off on the ends where it's held off by the uncompressed rubber gaskets. And even with that, 1/4 inch is a lot.
Old Sep 29, 2013 | 07:45 PM
TedH's Avatar
TedH
Installed the Milodon 30701 pan (1980 right-hand dipstick), stock volume oil pump and new fel-pro 1-piece pan gasket. I found that some time since 1999 rebuild, I had used gasket sealer on the rear bearing cap surface where the pan seal sat and it may have been a problem. I cleaned that up and put fresh black RTV at all four corners of the seal and even dressed the 'strap' areas on both ends of gasket (facing the timing cover and rear cap) for good measure.
No leaks. I had some noise in/around engine at start-up. Sounded like my accessory belts were rubbing something or, worse, pan clearance. The sound cleared after a couple minutes while I was looking around the engine. I do have some exhaust leaks so I am going to fix those (header at cylinder head and header at pipe).
Update: Noise appears to be flywheel rubbing the converter splash pan. I think I tweaked the splash pan when positioning the starter (with splash pan in place but not attached).
Old Sep 30, 2013 | 10:03 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
U need an anaerobic sealer - pretty thin runny stuff - for the main cap to the block. I have answered the rear seal questn enough there should be plenty in the archives if u do search.
cardo0
Old Oct 1, 2013 | 01:33 AM
bluedawg's Avatar
bluedawg
Splash cover, i assume thats the same thing that I call the inspection cover, another item ive probably called by the wrong name.
Old Oct 1, 2013 | 06:56 AM
TedH's Avatar
TedH
We were both close: flywheel cover. Mine got a little close to the flywheel.
Old Oct 1, 2013 | 11:14 PM
bluedawg's Avatar
bluedawg
Im from the mid west originaly, i grew up calling most parts by the wrong name. Funy thing is the parts guy newexactly what you were talking about.
Old Oct 2, 2013 | 06:48 AM
TedH's Avatar
TedH
LOL. I know what you mean.
To Going for Three...
Old Oct 2, 2013 | 08:39 AM
drwet's Avatar
drwet
Did you make that Fel Pro gasket work? I am in the process of helping a buddy assemble his small block and he is having trouble getting an oil pan gasket to fit. The Fel Pro one piece gasket is very thick at the front, to the point where the bolts aren't long enough to engage the threads on the block. I have used the one piece gasket before without this problem. In fact I have one in my '79 now and it works perfectly, and I didn't have this problem installing it.
And before someone posts about the thick/thin gasket thing, we definitely have the correct part. The gasket is just so thick I can't believe that this is the way Fel Pro expects it to work.
Old Oct 2, 2013 | 09:58 AM
TedH's Avatar
TedH
Yes. Got the new 1-piece Fel-Pro gasket and Milodon pan 30701. About 1/4" gap on both rails until I snugged the rail bolts down. I did find that my ARP pan bolts are too short and had to resort to using the bolts that came with the pan gasket. That was convenient as they are stock length but have the stock heads (larger than the 5/16" ARP heads). No leak and I did apply black RTV to all four corners of the 1-piece gasket and added some to the 'strap' areas of the gasket for good measure. Glad it is fixed.
I note that both the oil pan and the aftermarket Canton timing cover mentioned using a seal with the thick front strap.
The Milodon pan is definitely more 'heavy duty' as the pan steel is thicker and the rails have better reinforcements at all 4 corners. And, I picked up clearance between my PS slave cylinder/linkage and the oil pan. A very good choice for the $120 I paid for the pan. Got some nice decals too
Old Oct 18, 2013 | 03:02 PM
TedH's Avatar
TedH
That scraping 'noise' was back with a vengeance after I pulled the headers in order to remove the flywheel cover and inspect for clearance. While I was at it, I applied thread locker and torqued the three converter bolts for good measure.
I now suspect distributor/cam gear issue. I may have a real problem. Going to pull the distributor this weekend. If distributor or cam teeth show wear, I will advise.
Question: Is it possible to 'dent' the torque converter? I was using a prybar between the flywheel and converter and wondered if I may have dented the converterr (causing the internal blades to scrape... it seems too heavy to dent with a prybar.).
