USA made brake rotors?
Old Apr 12, 2011 | 06:29 PM
DrVincennes's Avatar
DrVincennes
Default USA made brake rotors?
I'm trying to find a supplier of USA made replacement brake rotors. So far the only supplier I've found is Bairs. Does anybody have any experiece with this supplier's rotors? Any other supplier of USA made?
Old Apr 12, 2011 | 06:49 PM
mikep3's Avatar
mikep3
Blair is one, but CC might have US made.
I went to NAPA, but they just updated the site, looks nice but way too slow. After 10 min. I gave up, I got mine there three years ago.
They had a $40, $60 and $80 ones, the two higher priced ones were made in USA.
What price were you hoping to pay?
Old Apr 12, 2011 | 06:54 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I was told about this website by a buddy of mine. It says all their brake rotors are machined in the USA. Give it a look if you are interested. I cannot vouch for it personally though.
http://brakeperformance.com/brake-ro...ake-Rotors.php
Old Apr 12, 2011 | 07:03 PM
Paul L's Avatar
Paul L
Eddie,
The key word is "machined". You don't know where the metallurgical blanks came from.
Old Apr 12, 2011 | 07:27 PM
Eddie 70's Avatar
Eddie 70
Originally Posted by paul 74
Eddie,
That is the same thing I was thinking Paul. That's why I mentioned what they say on their website, "Machined In USA". I just put it up there just in case someone else may be interested.
Old Apr 12, 2011 | 07:36 PM
GUSTO14's Avatar
GUSTO14
You might check out the EBC's, they're manufactured in the UK according to their website. I've been using them on the wife's Acura's for a number of years now and never had any issues. I've also autocrossed a Miata on them for about 8 years (about 10k miles however) and they still look excellent. I believe that some of the vendors carry them, but this will give you an idea of the cost...
http://www.autopartswarehouse.com/se...29&No=0&Npp=10
Good luck... GUSTO
Old Apr 12, 2011 | 08:16 PM
DrVincennes
So far Bairs is the only supplier I've found whose webpage says made in the USA. I've learned that generally if the supplier is silent as to where manufactured, they are not USA. Generally made in China. I want to stay with rotors with the rivit holes. Zip, Ecklers, Van Steel, VB&P all range in the ~$60 price range. Another indication they are made in China. USA made are a bit more for standard replacement rotor.
Old Apr 13, 2011 | 02:15 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
As far as I know, no rotors are made in the US any more except for Wilwood's new Spec 37 rotors. I was told a couple of years ago, there were no more US foundries producing rotors. Most are China, Canada & Mexico. I buy mine direct from Bendix (with rivet holes) or my AC Delcos (non-rivet holes, which are Canadian) through my local AC Delco warehouse. Brian could be having them made for himself. Not sure.
Old Oct 17, 2013 | 11:15 AM
Gale Banks 80''s Avatar
Gale Banks 80'
Since the Rivet holes were installed to keep the Rotors from falling off wile the car rolled down the assembly line I'm not so sure that a new replacement ones from GM back in the day had them ?
Old Oct 17, 2013 | 11:31 AM
zwede's Avatar
zwede
It is perfectly legal to take a white-box Chinese rotor that is finished except for the lug bolt holes, drill the 5 holes here, and put it in a colorful box that says "Made in USA".
The law only requires that the last significant machining step was done here. Lug bolt holes qualify as you can't use the rotor without holes.
Buyer beware.
Old Oct 17, 2013 | 11:34 AM
qwank's Avatar
qwank
what about Wagner? I know their pads are made in USA
Old Oct 17, 2013 | 01:21 PM
Mike Ward's Avatar
Mike Ward
AFAIK, GM didn't sell rotors by themselves, only as an assembly with the hub or spindle. This is because of the obvious problems with runout.
You can thank the aftermarket for inventing separate rotors.
Old Oct 17, 2013 | 01:52 PM
7T1vette's Avatar
7T1vette
Although there is a higher probability that parts made in China are "suspect", being made there is not really the problem.
China can make "good" parts as well as "junk". It all depends on what material is used to make the parts and how they are heat treated. It is easy (and more inexpensive) to make parts that LOOK like the proper configuration than to make parts that are functionally equivalent to factory-made parts. And, it is impossible to tell the difference by looking at the parts.
My approach for selecting good quality "hard" parts (steering, suspension, engine, etc.) is NEVER to purchase the least expensive available part. You can be assured that the least expensive part is "junk". If you have some good brands of parts, go that way.
Finally, GM buys ALL of its parts, since it no longer has any manufacturing facilities. But, GM probably specs those parts appropriately; but they also charge a significant premium for that Chinese box with the GM logo!! So, I rarely buy a GM part...unless that's the only way to get one. (same with going to the "Zone"...)
Old Oct 17, 2013 | 03:38 PM
Tom454's Avatar
Tom454
I have a full set of new, in-the-box, Delco "A Product Of GM" rotors. I bought these 1978-1980. Are these considered GM rotors? The front rotors have the hub.
Here are the numbers on the boxes:
5473381
5473382
Old Oct 17, 2013 | 08:40 PM
stock76's Avatar
stock76
With this Global Economy, things may have changed, but NAPA's Ultra Premium rotors were made in the USA. Actually, the box and printed instruction sheet that they came in were exactly the same as Bendix' USA made rotors.
NAPA's "Premium " rotors said made in China on the box.
Delco is Chinese made last I checked.
If you want USA made rotors its best to check the box for country of origin to make sure.
Probably the Rotors on most new cars are sourced from China these days so..........
Old Oct 17, 2013 | 09:40 PM
Mike Ward's Avatar
Mike Ward
5473381
5473382
Delco sold them, not GM as I understand it..
Old Oct 17, 2013 | 10:26 PM
Indiancreek's Avatar
Indiancreek
Eddie,
exactly
To USA made brake rotors?
Old Oct 17, 2013 | 11:52 PM
claysmoker's Avatar
claysmoker
St. Jude Donor '09-'11-'12-'13-'14
The original rotors on my 2002 C5 were made in Brazil, and the calipers in Australia. After 62K miles I just surfaced them and put on new Porterfield pads. Good as new again! FWIW I looked at NAPA Ultra Premium rotors, and they are made in China. The workmanship is flawless, but who knows what the material is like?.
Old Oct 18, 2013 | 08:20 AM
aussiejohn's Avatar
aussiejohn
Default Made in Australia
G'day,
If the calipers are made in Australia (which ALL Corvettes have used since 1983!) then rest assured that they will be of good quality. GM owns General Motors Holden in Australia and the local brake manufacturers have to make their products to the GMH standard. When supplying to GM USA, the quality has to be of at least the same standard as for the local cars.
They'd lose a valuable export contract if they cheaped out.
Regards from Down Under.
aussiejohn
Old Oct 18, 2013 | 09:10 AM
Tom454's Avatar
Tom454
That is correct. I worked in an autoparts store at the time which sold Delco Brake Parts, and that's where I bought them. But the box has "A Product Of GM" printed on it. Was Delco Brake a GM Division at the time?
Also... the actual GM Parts Catalog Revision 11-81... Section 5.09 p.5-10 lists
"DISC, RR" 1965-1982 #3996663
"DISC, W/HUB, FRT" 1965-1968 3998278
"DISC, W/HUB, FRT" 1969-1981 3991024
Do you think the GM Catalog numbers crossed to the Delco numbers? In other words, if I walked into a Chevy Dealer in 1981 and purchased a rotor, would it have been in the Delco box? I'm not clear on the whole GM/Delco relationship back then.
Edit: Ecklers has these numbers listed on their web site as well as OEM numbers.
