Illuminated Toggle Switch-Why a Ground
Old Apr 17, 2011 | 08:21 AM
Paul L's Avatar
Paul L
Default Illuminated Toggle Switch-Why a Ground
In one of my latest projects I am using a simple on-off toggle switch to control a lighting system. So power in one side and out the other when the circuit is closed. It works fine. I was thinking of replacing that unit with an illuminated version but those switches have a third terminal marked ground. What is the purpose of that ground? Surely the lighting system is grounded already as it now works fine. Basically I just want that illuminated tip to light up when power is flowing and go off when the circuit is open. Can I ignore that ground terminal under these circumstances?
Old Apr 17, 2011 | 08:22 AM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
it is for the light in the switch.
Old Apr 17, 2011 | 08:44 AM
Paul L's Avatar
Paul L
So the light in the switch is grounded separately from the overall circuit?
Old Apr 17, 2011 | 09:02 AM
SIXFOOTER's Avatar
SIXFOOTER
Yes
Old Apr 17, 2011 | 09:22 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Originally Posted by SIXFOOTER
Yes
The light in the switch needs a ground to work.
Old Apr 17, 2011 | 09:45 AM
Paul L's Avatar
Paul L
Thanks for the replies. Much appreciated!
Old Apr 17, 2011 | 10:32 AM
mikejpss's Avatar
mikejpss
Where can I send my bill ????
Old Apr 17, 2011 | 01:11 PM
toddalin's Avatar
toddalin
Kind of hard to ground a plastic switch using the treads on the case.
Old Apr 17, 2011 | 07:26 PM
Paul L's Avatar
Paul L
The fruits of your advice. Thank you. The switch is metal (the pic above was just illustrative to show the three terminals) but the small black panel in which it is sitting is insulated from the frame by dash panel trimming. So I ran a black 16-gauge ground wire to a screw under the dash right on the framework. Works fine and the little LED tip is surprising bright. High tech in a 1974 .
Old Jul 19, 2011 | 12:21 AM
davidb1's Avatar
davidb1
1st Gear
Hey, Paul 74, I just stumbled across your post. Did you get it figured out for it to work the way you wanted? Does the light go off when the switch is off? If not, you should be able to wire the light's ground into the 'after-switch' circuit and use the main circuit's ground. Then, the switch's illumination circuit will only be complete when the switch is on and the main current is completed. Just a thought if the light isn't going off when the switch is off!
Old Jul 19, 2011 | 06:47 AM
Paul L's Avatar
Paul L
That switch controls my daytime running lights (DRLs) and it works exactly as it should, i.e. LED is on when lights are on. And of course off when lights are off.
Old Aug 29, 2012 | 08:05 PM
Paul L's Avatar
Paul L
The DRL module went south today so with some (actually pretty extensive) extraction of wires and some minor re-soldering I am back to factory specs on the front parking lamp extensions. Too bad; I liked those DRLs. The supplier will longer ship to Canada (???) and of course I have lost confidence in the product in any case. A friend's module from the same company went bad as well. Nice experiment but not a nice outcome.
I will be now looking for driving lamp options. The IGN wiring to the front is still there as is the LED toggle switch under the dash but it is disconnected at the fuse box. So that circuit is not hot, but could be very quickly. I will be looking at driving lamp options in the near future.
Old Aug 29, 2012 | 11:07 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Just for kicks, what's in the DRL module? The concept seems simple, so I'm perplexed about the lack of reliability of that device.
To Illuminated Toggle Switch-Why a Ground
