Engine Knock on hard acceleration
Old Apr 26, 2011 | 02:26 PM
Ravine Speed's Avatar
Ravine Speed
Default Engine Knock on hard acceleration
took my '69 L71 (427/435 Tri-power) out for the first time on sat (seattle, nice cool day) and all was great, cruising at 70 or lower.
Car was warmed up, half hour of driving and when I accelerated hard, it knocked petty loud, and spooked me. Back at cruise 3500-4000 rpm all was well.
I am hopeful this is fuel octane problem, it's the gas that has been in the car since Jan, don't remember if I used octane boost or not.
Thoughts?
Old Apr 26, 2011 | 03:44 PM
LB66383's Avatar
LB66383
That fuel is kind of old. You could also have water in the fuel, condensation from just sitting there all of those months.
Old Apr 26, 2011 | 04:57 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The fuel shouldn't break down in 3 or 4 months. Was the tank full before you parked it? You will get more moisture in the fuel if there is alot of open space in the tank.
It could be a timing issue. I would drive it gently until you can get some fresh gas in there and see if it still does it. You may have to dial back the initial a bit.
Old Apr 26, 2011 | 05:18 PM
69vettester's Avatar
69vettester
Do you know what a rod bearing sounds like when it first gets flat? If its not that You lucked out and its likely just a octane knock .
Old Apr 26, 2011 | 06:51 PM
Ravine Speed
Thanks for the insight. Fuel tank was only about 1/2 full, very possible condensation got in there. I'll run it empty gently then get some 93 and octane boost in there and see what happens.
To Engine Knock on hard acceleration
