Need steering help
Old May 1, 2011 | 01:11 PM
javier's Avatar
javier
Default Need steering help
Need help with my steering . Just took out my 71 big block with power steering , drove it on the highway first time this year , the car was all over the road wandering from left to right . This car was restored about three years ago , I have new everything including the steering valve , steering box rebuilt and blue printed by GTR1999 and its tight as can be , new GM steeing coupler and rag joint , installed a heavy duty idler arm tierod ends are new had an alignment and she drives like crap . Its to the point it is dangerous to drive over 65 mph . Am I missing something any help would be appreciated thanks in advance .
javier
Old May 1, 2011 | 01:54 PM
Peterbuilt's Avatar
Peterbuilt
WOW! Everything in the front sounds like it's new. How's the rear? Are the trailing arm bushings OK.
Old May 1, 2011 | 02:09 PM
javier's Avatar
javier
Yes, everything is new, just can't figure it out.
Old May 1, 2011 | 05:11 PM
doctorgene's Avatar
doctorgene
Yes Sir; I had one bad shock which created the same problem. Please let us know what you find. Have a great one. Gene
Old May 2, 2011 | 12:06 PM
javier's Avatar
javier
Have no clue , shocks are new .
Javier
Old May 2, 2011 | 01:23 PM
Rally68's Avatar
Rally68
New doesn't always equal good. I have had a strut rod bushing from a reputable supplier fail after 300 miles. You need to inspect your suspension and steering until you find the culprit.
Good luck!
Old May 2, 2011 | 01:44 PM
1Fordman's Avatar
1Fordman
What's the toe-in set at?
Old May 2, 2011 | 02:50 PM
doctorgene's Avatar
doctorgene
Yes Sir; My shocks were brand new also, as well as the complete suspension, front & rear. They were the last thing I bought, I did buy 36.00 ea, set. Bought Blisten this time. Not saying yours are bad, just might be worth checking. Have a great day. Gene
Old May 2, 2011 | 08:18 PM
7T1vette's Avatar
7T1vette
I would suspect a bad idler arm or loose idler arm bolts. But, there are many possibilities in the steering system that could cause those symptoms.
Old May 2, 2011 | 09:48 PM
wombvette's Avatar
wombvette
Check the balance on the steering valve.
Old May 3, 2011 | 08:27 AM
javier's Avatar
javier
Thanks guys , have a list of items to check , will keep you posted on the results .
Javier
To Need steering help
