Engine help
Old May 5, 2011 | 10:56 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Originally Posted by boltnut
the contradiction here is wanting to do it cheap AND wanting to do it yourself. i bet by the time you learn how, mess a few things up, and buy all the tools and equipment, you will be money ahead to purchase a crate......JMO
He may be like me and need to experience the task before he understands what you mean. Translation: buy the crate & do yourself ,your checkbook and your family a favor. You want the experience of "building"? Go to the local junk yard, buy a $50 klunker motor, take it home & tear it down. Then put it back together. Presto- $50 learning experience.
BUY A CRATE, save the headache and get a 2 year/50k mile warranty.
ask me how I know.....
Old May 6, 2011 | 01:38 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
No one is asking you the important questions. What rear end gear do you have? what trans? what is your intended use, race, street, highway cruiser, street/strip? How many max RPM will you run and how often. These are critical to building what matches your needs and component selection. I realize you want to build your own engine. There is a satisfaction that comes with that that a crate engine can't replace. Answer these questions and have a good machine shop lined up and get back to us. You will get many opinions and conflicting advice.
Old May 6, 2011 | 03:08 PM
Rich's'78's Avatar
Rich's'78
I also agree with Mako. I believe if you want more than 300 FW ponys and a nice daily driver that won't kill you on the gas $ you have to get aftermarket heads to get there. Most guys go with more cam but then you lose the low rpm throttle response and decent gas mileage. You gotta know your diff ratio and work it from there.
Old May 7, 2011 | 01:07 PM
S1NE5TER's Avatar
S1NE5TER
I have the original 4-speed, My intended use is street/strip. However, leaning more on street.
However, I don't know what the rear end gear ratio is. How can i found out? Also I'm not sure about the max RPM i would like to run. What would you suggest for a street/strip build?
Old May 7, 2011 | 01:41 PM
trainor's Avatar
trainor
Originally Posted by S1NE5TER
thanks guys!
Im researching everything with the prices. If you guys have more advice post them up
I rebuilt my 75 L48, Brodix heads, 30 over Keith Black pistons, Erson Cam, Elel Intake, 650cfm edel carb, McJack headers, true dual exhaust, 400 tranny with shift kit. Car runs great, but........I would have been better of with a crate. My .02 worth. Good luck
Old May 7, 2011 | 04:35 PM
mar's Avatar
mar
Old May 8, 2011 | 12:26 AM
63mako's Avatar
63mako
Need differential ratio. Bottom of the carrier right in front of the cover has numbers stamped in it. The code will tell what gears came in the carrier. Or jack the rear up and rotate the tire 1 revolution counting how many times the driveshaft turns. 3 plus a little is a 3.08, 3 plus 1/3 is a 3.36, 3 and a half is a 3.55, 3 and almost 3/4 is a 3.70, 4 and a little is a 4.11. A 3.08 will not take a real high HP build due to the gearing. A 4.11 you can build over 500 hp and maintain streetability with a manual trans.
Old May 13, 2011 | 12:22 PM
S1NE5TER's Avatar
S1NE5TER
hey guys,
quick question....
Are the parts sold in GMPP overpriced compared to aftermarket such as summit racing, edelbrock and year one?
thanks
Old May 13, 2011 | 03:42 PM
Red 69's Avatar
Red 69
hey guys,
quick question....
thanks
You can try Scoggin Dickey http://sdparts.com/ They are not always the least expensive, so stop and check prices at Jegs and Summit before you buy. www.jegs.com and www.summitracing.com respectively. GMPP rips you off big time on shipping.
