Spark Plug Wire Question
Unless you're going for NCRS type judging, you don't want these specific wires anyway- terrible reliability.
I failed to mention that I am looking for the cables with the braided shield. The on-line vendors list two parts, depending on whether it is an early or late production model. I would like to know what the difference is between the two parts.
Perhaps WILCOX can jump in, as they offer two items.
All the vendors I looked a listed 2 sets as you've said, but from what I read it only has to do with date coding on the wires. Not a difference in the wires.
Did I miss something that you saw?
Regards,
Alan
The only difference between the "early" and "late" wires, is the date on them. Physically, there is no difference to them.I think they figure the break for the dates, to be at some point around VIN 17,500 to 17,600. So if your VIN is between 00001 and around 17,500, buy the early ones (3rd qtr 1968). If your VIN is higher than 17,500, buy the late 69 wires (1st qtr 1969).
Actually, there should be 3 sets sold for 1969. 1969's were built for 16 months. Anyone with a very late 69 (one with a VIN after about 28,100), who buys the wires advertised for late 69's, will get wires dated 1st qtr 69. Since 69 production continued into Dec. 69, the wires sold as late 69 (with a 1st qtr 69 date), would be to early for a 69 built between August and Dec. 1969. Someone with a 69 built after Aug. 69, should be buying the wires listed for early 70, the ones dated 3rd qtr 69.
If your not doing NCRS, you don't need the dated wires. You can save a few bucks by buying the un-dated wires. Not all vendors carry them, but they are available, and cost about $15 less than the dated ones. That's enough of a savings on them, to pay for the freight.
You can barely see the dates on the braided wires anyway, the braiding hides all but about an inch of it on each end of the wire.
I didnt really see any reference to the difference other than there were different items depending on early or late. You've cleared it up for me.
Thanks Glenn
Maybe try to find a used braided set on eBay and put modern black silicone 7mm wires inside?
