Speedo calibration
Old May 10, 2011 | 03:35 PM
robs68's Avatar
robs68
Default Speedo calibration
I have a 1968 with the original m20 4 speed. My speedometer is off. My tire size O.D. 26in. and my gear ratio is 3.73.Does anyone have the formula to get the correct speedometer gear. Thanks
Old May 10, 2011 | 04:27 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I think 26" is app. stock tire dia. (26.2 is stock I think.)
therefore you need a speedo gear to match the 3.73 rear end.
they list the gears by color to match the various ratios.
Old May 10, 2011 | 04:31 PM
joewill's Avatar
joewill
you will need to know your speedo drive gear number of teeth inside your transmission that is pressed onto your tailshaft. it is the gear that meshes with your speedo driven gear at the end of your speedo cable at the tranny.
then you can mathematically calculate it and base the calculation on 60 MPH equals 1000 rpm of the speedo cable.
another thing you can do is determine your speed via GPS and determine what percentage off your speedometer is and then call these guys to build you a add on box that will increase or decrease your cable speed the correct amount.
http://www.redrider.us/Speedometer_Gears.htm
or you can try several driven gears ( they are cheap ) until you get close to what your real speed is.
for example:
http://cgi.ebay.com/ebaymotors/MUNCI...Q5fAccessories
Old May 10, 2011 | 04:38 PM
Alan 71's Avatar
Alan 71
Hi Rob,
69V was very close ... I checked to make sure and found that the original Goodyears were about 26.9" in diameter.
I'm sorry but I don't know if or how that may affect the calculation for the proper transmission speedo gear for your new tires.
Regards,
Alan
Old May 10, 2011 | 04:44 PM
Mike Ward's Avatar
Mike Ward
If you speedo and odo are both off this can be corrected by changing the tooth count of the driven gear. I think a change of 1 tooth = 6 mph but am not sure.
If your speedo is off but not the odo, the unit needs to be repaired.
Old May 10, 2011 | 06:06 PM
7T1vette's Avatar
7T1vette
Actually, it's more like 3-4 mph per tooth change. Adding teeth will result in a lower speed reading (from previous condition); reducing number of teeth will cause reading to increase.
Old May 10, 2011 | 06:07 PM
captl27's Avatar
captl27
here is a old post that might help you out
http://forums.corvetteforum.com/c3-t...r-replace.html
Old May 10, 2011 | 07:03 PM
Mike Ward's Avatar
Mike Ward
Yup you're right, not 6 mph.
To Speedo calibration
