not able to close side window
Old May 11, 2011 | 03:59 PM
68_vette's Avatar
68_vette
Cruising
Default not able to close side window
My right side window is imposible to close all the way up. I have a one inch plus cap between the top of the window and the weatherstriping for the convertible roof.
I am able to grab the window and pull it up to the correct position, but then the window motor is not able to drive the window down again since the window motor is not engaged with the theet in the window mechanism.
The problem seems to be that the mechanism does not have enough theet to drive the window all the way up. By the look of the part I have the corrrect mechanism for electric window. But the car has been converted from manual to electric windows a long time ago. Please help, otherwise it will be impossible to pick up girls with this car in rainy Norway this summer.
Roger.
Old May 11, 2011 | 04:18 PM
thegazman's Avatar
thegazman
Default thegazman
Did you look to see if the teeth on the window regulation are in good shape? Maybe the teeth at the end of the regulator gear are worn or broken.
Old May 11, 2011 | 04:46 PM
68_vette's Avatar
68_vette
Cruising
Yes, I have removed the mechanism from the door and checked it. It appeared to be in good shape. Thanks anyway
Old May 11, 2011 | 05:05 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Sounds like you might not have the regulator spring tensioned sufficiently.
Old May 11, 2011 | 05:27 PM
68_vette's Avatar
68_vette
Cruising
When the window is as high as it will go with the motor, I can hear the motor running and that the the motor is no longer getting any grip on any more of the theet, since it is at the end of the part. I can theN pull the window up by hand, and the motor is then not able to get in touch with the theet.
To not able to close side window
