Harmonic Damper
Old May 16, 2011 | 11:20 PM
Bud2's Avatar
Bud2
Bud2
Default Harmonic Damper
Guess I don't really know what I need for a 383 stroker. Different sizes, different construction. Or do I just ask the rotating assembly manufacturers' opinion?
Thanks.
Bud.
Old May 17, 2011 | 12:22 AM
Grumpy 427's Avatar
Grumpy 427
To start with i am thinking it should be an 8" external balance unit. If your rotating was external balance.
Old May 17, 2011 | 03:03 AM
Bud2's Avatar
Bud2
Bud2
Default Sorry,
I'll balance internally.
Bud.
Old May 17, 2011 | 09:46 AM
pauldana's Avatar
pauldana
im using the ATI Fluid damper:
http://www.atiracing.com/products/da...amper_tech.htm
Amazing damper.... I think it was gkull that sent me that direction...:thu mbs:
Old May 17, 2011 | 09:52 AM
7T1vette's Avatar
7T1vette
You should ask for the builder's opinion. The dampers are balanced when manufactured (or, they are supposed to be). Their purpose is to dampen out 'uneven' power pulses during the rotation of an internal combustion engine. It needs to be matched to the harmonic vibration behavior of the engine. Your builder/balancer should make a recommendation. If no recommendation is made, install a good quality balancer for a Chevy SB engine.
Old May 17, 2011 | 11:20 AM
Solid LT1's Avatar
Solid LT1
Lots of Chinese made junk in the dampner markert. The smartest engine builder I know uses ATI dampners but he thinks Fluid Dampners (USA made only!) are pretty good too. He dosen't quite know what to think of the TCI "Rattler" I showed up with on my current build but. Comp Cams gave us a good deal on it and I want to try it (hoping it adds tot he harmonics of the motor)
To Harmonic Damper
