Pedal Support Plate Rivets?
Old May 17, 2011 | 02:19 PM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
Default Pedal Support Plate Rivets?
My 73 project started by just cleaning the interior of years of dust, dirt and spiders from being stored outside for the better part of 8 years
It has since turned into a complete interior gut and when taking off the pedal assy (it's a manual) I noticed bubbling rust on the outside support plate riveted to the firewall by the wipers. It is held in place by two rivets.
I have to replace the plate and since the rivets are visible, would like to use stock (appearing) fasteners. Does anyone have a source for the plate and more importantly, the rivets and method for installing them at home?
Old May 17, 2011 | 06:43 PM
Alan 71's Avatar
Alan 71
Hi C,
I'm not sure just which plate you're referring to.
Do you see it from the engine compartment, wiper well, or interior?
And are you seeing the head-end of the rivets or the 'set'-end?
Trying to help!
Regards,
Alan
Old May 17, 2011 | 07:18 PM
C2C6Z06's Avatar
C2C6Z06
Thanks Alan, you see the plate from the wiper well and it appears the peened end of the rivet is showing to the well.
I'll get a pic up tonight.
Old May 17, 2011 | 08:44 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If the plate is number 6 below.. then yes you can put standard rivets in there. It won't look factory but you can do it. Does anyone make that plate... Nope, I'm sorry there currently is not a reproduction. I think this could be fabricated up with little difficulty though. I may have a good used one, I'd have to check.
Old May 17, 2011 | 11:01 PM
C2C6Z06's Avatar
C2C6Z06
Wilcox, thanks for the reply...it seems I need your catalog
Here are two pics, and yes, it seems to be #6:
Old May 18, 2011 | 08:50 AM
avner's Avatar
avner
C2C6Z06
Take the plate out and make a copy from it, that what I did.
I install it back with the original rivets that I bought from Paragon.
http://forums.corvetteforum.com/c3-g...-question.html
Avner
Old May 18, 2011 | 10:39 AM
C2C6Z06's Avatar
C2C6Z06
Thanks Avner, you aren't selling that rivet gun anytime soon are you? :-)
Old May 18, 2011 | 11:03 AM
Alan 71's Avatar
Alan 71
Hi c,
It looks like you might have enough room working from each side to set the rivet in the normal way with a 'buck', on the head side, and a hammer/large nail set, on the shaft side.
Regards,
Alan
Old May 18, 2011 | 09:49 PM
0Willcox Corvette
Former Vendor
The factory rivets were a soft aluminum rivet.. they are very easy to install. If you want me to check for a good used one.. just email me at willcoxcustomerservice@willcoxcorvette.c om
Old May 19, 2011 | 03:32 AM
avner's Avatar
avner
No, but you can find them in Ebay $50-$100
Look for rivet gun.
Ebay# 200608365878
Ebay# 200608365878
Old May 19, 2011 | 10:45 AM
C2C6Z06's Avatar
C2C6Z06
Thanks everyone....I think I will fab the plate myself. Then decide whether to spend for the rivet gun or use pop rivets...
Old May 19, 2011 | 11:17 AM
7T1vette's Avatar
7T1vette
Unless you are striving for the "perfect car", go with the [correct size] Pop-rivets. Who the heck will ever know...except you?
To Pedal Support Plate Rivets?
