70 diff on a 72 Corvette
May 25, 2011 | 07:14 AM
Navigator
Can I put a 70 diff (2CAM 3 3 70 W) 0n a 72 corvette-350/350???
May 25, 2011 | 07:27 AM
May 25, 2011 | 07:33 AM
Yes, all 65-79 rears are basically the same.
63-64 rears fit, but are different internally.
May 25, 2011 | 07:39 AM
Navigator
Thanks.
May 25, 2011 | 07:55 AM
Quote:
Originally Posted by
gbvette62
Really? What's different about them?
I have a '63 rearend in my '69 right now.
May 25, 2011 | 08:00 AM
Navigator
Pictures of changing rearweel bearings?
Has anybody pictures of change of rearweel bearings,what i have heard is a big job!?!?
May 25, 2011 | 10:45 AM
sijvette
Only difference may be the pinion flange. If the 70 diff came from a 4 speed car you will have to change the flange or get a conversion u-joint.
Mike
May 25, 2011 | 11:11 AM
bashcraft
The 63-64 posi unit, ring and pinion, etc. are different. The 63-64 is a Dana unit, while 65-79's use an Eaton. There are very few parts available for a 63-64 rear, but they can be updated by installing 65 up components in them.
tracdogg2
Mike
If need be, he should be able to reuse the front flange, from his existing rear.
May 25, 2011 | 11:38 AM
gbvette62
Sorry to hijack the thread, but one more question. Is one stronger than the other?
May 25, 2011 | 11:42 AM
The 63-64 Dana unit is very weak. Odds are it has already been changed out with an eaton unit.
Mike
May 25, 2011 | 12:13 PM
tracdogg2
Mike
May 25, 2011 | 12:18 PM
tracdogg2
Mike
So if mine has held up behind a zz502 for the last 2 years, it's safe to assume that it's been changed out?
May 25, 2011 | 01:43 PM
There's no way the Dana unit could handle a 502.
Mike
May 25, 2011 | 02:08 PM
tracdogg2
Mike
Thanks!
