never starts on first try....
Old May 28, 2011 | 04:37 PM
johnmb's Avatar
johnmb
Inductors and capacitors both take time to charge. Two seconds is an eternity UNLESS there's a large series resistor limiting the current into the L or the C. That's the only electronic reason I can think of to wait 2 seconds.
Unless there's vacuum tubes in there that need some time for the filament to start boiling off electrons :-)
John
Old May 28, 2011 | 04:59 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader vette
Originally Posted by imariver
Ok, I started it cold, drove to the hardware store, came out and started it hot. Both times I turned the key on, buckled my seatbelt and then started the engine. Both times it fired right up. NO Problem!! But now I'm worried about all that extra juice and where it's going.................
You need to drink the juice with your PIE.
Old May 28, 2011 | 05:20 PM
...Roger...'s Avatar
...Roger...
John
Its been awhile, and they might have said magnetize instead of charge.
Would that make more sense ?
Old May 28, 2011 | 05:24 PM
...Roger...
Try just a momentary pause before cranking,before the starter gets all the current.
Do you guys still have the yellow wire coming from the R term on the solenoid hooked up to the coil ?
Old May 28, 2011 | 09:19 PM
imariver's Avatar
imariver
On the coil, there is a black wire and a brown wire connected to the positive side. The brown wire is covered by a white braided jacket. Both of these wires dissapear into a wiring harness. A red module in the distributor has a red and black wire, the red wire is on the positive side of the coil and the black wire is on the negitive side. Right above the red module is a black disk attached to the rotor. Don't see any yellow wire and the harness is the original factory. I have started the car a couple more times, (using the "2 second" method) and it has fired right up every time.
This is a stock L-48 BTW
