Voltmeter for a 73
Old Apr 22, 2002 | 05:31 AM
Jvette73's Avatar
Jvette73
Default Voltmeter for a 73
My current in dash ammeter was fried by my aftermarket 100amp alt. The needle is slightly above the center posistion and is stuck there whether the engine is running or not. I was warned that this might happen when adding the 100amp alt. Well I was correctly warned because it did stop working right after the new alt was installed. My question is, When did GM begin using voltmeters in C3 vettes instead of ammeters? I would actually prefer a voltmeter over an ammeter. Are thier any other model years which use a volt meter that would fit my cluster and have the same appearence as the other guages in the center cluster? Or maybe an aftermarket or resto company who offers a matching voltmeter instead of ammeter for a '73?
Old Apr 22, 2002 | 08:14 AM
mrvette's Avatar
mrvette
Default Re: Voltmeter for a 73 (Jvette73)
The voltmeter out of a mid 80's chevvy pickup fits and works fine....tie the two ampmeter wires together, and connect them to the + term on the voltmeter, negative to frame, and it's dun.....
Old Apr 22, 2002 | 11:00 PM
Jvette73's Avatar
Jvette73
Default Re: Voltmeter for a 73 (mrvette)
Thanks for the tip mrvette, I have a 84 fullsize blazer. I checked the size and it looks very similar. I need to look around at other years to see if I can find one that matches the other vette gauges better. I.E. The blazer gauge has a thicker and different color needle and numerals and stuff. My better half is kinda picky about details. Unlike me, she wiould prefer a broken guage that looked identical rather then a functional one with slight differences in apearence. I wonder if any of the corvette specific vendors make or sell a voltmeter with exact same apearence to replace original ammeter. Im gonna go check some catalogs and see. If no one makes these they otta. I would buy one.
To Voltmeter for a 73
