BB Cam Change
Old Jun 3, 2011 | 02:47 PM
bigvette1's Avatar
bigvette1
Default BB Cam Change
Has anyone changed the cam, balancer and timing set on a BB 454 A/C car with the engine in the car with A/C? The question is -- is it worth the disassembly or is just pulling the engine more practical?? Thanks
Old Jun 3, 2011 | 03:17 PM
C6DuffMan's Avatar
C6DuffMan
I'd like to know too. I have this job in my future.
Old Jun 3, 2011 | 03:57 PM
Little Mouse's Avatar
Little Mouse
No reason to pull the engine for a cam change. You would end up messing with a bunch of extra work for no reason, transmission, exhaust manifolds or headers.
ja1724's Avatar
ja1724
St. Jude Donor '12
I'm pretty sure I've heard of people changing the cam while the motor is still in the car. You definitely have to pull the rad,rad support,condenser etc. This is still less work than pulling the motor.
I changed a cam in a 69 Chevelle with the motor in. I had to pull the grill and the front bumper off to get it out though.
Old Jun 3, 2011 | 04:49 PM
Little Mouse
Just lay the compressor/bracket over to the side. Pull the radiator, slide cam out.
Old Jun 3, 2011 | 05:44 PM
bigvette1's Avatar
bigvette1
Probably right on the amt of work. Just wondering if that would be a can of worms. Good excuse to work on the cooling system also. Thx
Old Jun 3, 2011 | 05:58 PM
zwede's Avatar
zwede
I've done it. Not a bad job. Actually didn't empty the AC, rotated the condenser out of the way and the cam just barely made it past. Pretty sure I removed the hood (it's been a while).
Old Jun 4, 2011 | 12:41 PM
Mr. Beam's Avatar
Mr. Beam
And you can even keep the hood on, but you need to close it just a little to get the last inch needed of clearence.
I found the biggest PITA was to seal the oilpan - timing cover ....
/ Mr. Beam
Old Jun 4, 2011 | 06:29 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
/ Mr. Beam
Yeah, that's a pain. Next time take a pair of tin snips and trim the gasket lip ears on the timing chain cover. Then it slips right in w/o screwing with the oil pan.
Old Jun 4, 2011 | 09:12 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
keep in mind your C3 operates a bunch of vacuum acc.
more Cam = less vacuum.
going with too big a Cam, can open up a whole new can of worms.
Old Jun 5, 2011 | 10:28 PM
radiotexas's Avatar
radiotexas
Default 454 cam change
I've run into the big after market cam problem on a Vette and a Chevelle. On a whim, I tried RHODES lifters. Sweet mother of honest advertisng! They do exactly what the manufactuer says they will do. Both cars immediately developed nice manners and vacuum problems went away.
To BB Cam Change
