Rear wheel hop issues!!!!
Converted my vette to a 5spd with a TKO600, and now I have bad rear wheel hop under heavy to WOT in first and second gear. No other changes to anything else.
What is the cause of this? Does an automatic with it's fluid coupling act as a sort of shock absorber? How do I eliminate this issue?!?!?
edit--- could the driveshaft be too long ?
If it was loose or worn, explain to me how this didn't happen with the auto tranny?
My curent rear suspension:
-100% poly bushings
-VBP trailing arms
-VBP adjustable struts
-Carrera 3 way adjustable shocks (set at 2)
-VBP 360# spring
-VBP 3/4" sway bar
-VBP rear diff locator discs
-Spicer 1350 u joints
-custom made 3" half shafts
Here is a pic:
I ran a 'glass spring for awhile, but went back to a 5 leaf steel one with an added leaf and QA-1 shocks to get rid of my wild bouncing ride down the track!
JIM
I went from a 383 to 427 auto to a TKO 600with a 500 + steel rear spring and I had rear wheel hop in 1-2 so bad. I thought that i would break something.
With all the fixes it came down to placing a one inch block under the rear of the tranny mount point. It does not give the front of the rear diff snubber whether made of poly, rubber, al. to move.
The drive shaft is a straight line.
It sounds goofy but ............... I have 335/35/17 street or big *** road racing slicks rear tires
Those are 3 1/2 inch exhaust pipes with a 4 inch ovaled tube cross pipe under the rear diff
I notice you have the left spring bolt cranked up more than the right,is that due to a body lean ?
Did you have a new driveshaft made or a new yoke installed on the old shaft ? If the driveshaft is slightly long it will bind as the differential nose comes up causing a load and unload condition.
JIM
I know that there is a "traction bar" made for these cars, I am wondering if that is also something worth looking into.
No more hop, but....it does transmit a lot of noise through the frame/roll bar. Not for the squeamish
I wonder if it might be your rear tires. When I had wheel hop I was also spinning the rear tires. I had what looked good 315 heat cycled crusty rears. I would go into wheel hop and have to lift off the gas and when I refloored it it would go right back into wheel hop. I did the tranny rear lift, cross disks and rear tires and it went away
Traction bar (I have one) will keep you from damaging the differential housing and/or front yoke. Won't do bupkis stopping wheel hop. I also have the aluminum cross member mounts. Can't say thay actually did anything.
The spring keeps your wheels planted and the shocks dampen the up & down motion. So a stiffer spring may help. I'd Start with adjustable shocks, Cheap and easy. If that doesn't resolve the problem, then try some of the solid mount suggestions some of the others recommend.
