Does the number really matter on a Q-jet?
So, does it matter? Do I need to look for a 7040207 or will any old qjet work?
Lars Grimsrud is the 'guru' for info on Q-Jets. If you find a candidate carb, e-mail him with the numbers on it and tell him what car/engine/transmission you have, and he should be able to advise you of how to alter it appropriately. V8FastCars@msn.com
Some of the numbers refer to California or manual transmissions. This may mean that it will have more vacuum ports than you need or fewer than you require, depending on your set up. From the factory these are set up different but you can make adjustments for your needs.
Later Rochesters have more emissions equipment with them. These can be removed if required for your application or lack of interest in emmissions.
In short, yes, you can take any old Rochester and get it to work for your application (insert disagreement/discussion here) The bodys are basically the same (except for additional ports) and it was the set up from the factory for each that changed.
If you want the carb that was on your car then get the numbers that match. If not then numbers that are closer (in terms of date)will help
I agree that Lars is the Q-Jet MAN.
I'll add that I believe some q-jets had the fuel line fitting at the front while some have the fitting on the side. I'd think that would be an issue to watch out for in finding a carb.
Regards,
Alan
http://www.cliffshighperformance.com...carb_ID_2.html
If you feel inclined, you might want to pick up a copy of Cliffs book, How to Rebuild and Modify Rochester Quadrajet Carburetors by Cliff Ruggles It is well worth the price. It will not make you a Quadrajet Master, but you will definitely feel much less intimidated by it.
Cliff is one of the folks that Lars Grimsrud speaks highly of and they share a lot of their Quadrajet knowledge with each other.
To answer you original question, Yes and No... Yes, it does matter and no, any old Quadrajet will not work, at least not well. There is much more of a difference between Quadrajets than you might think, However if you at least attempt to stay within the series that came with your generation of car, you will find life is much simpler.
Good luck... GUSTO
(IMAGE)
Good luck... GUSTO
Other than those I was hoping that they'd be pretty similar. I've thought about just dropping the $240 at Eckler's for one cuz I feel I could be pretty confident that I'd get the right one.
If only I lived in CO (unless Lars has moved since I was on here last). It's been a while since I
ed around this place.
IMHO the number does matter. My 71 Cadillac came with a Q-jet. Which means a
472 cubic inch. I doubt that
carb would work well on a
350/383.
So numbers do matter. Although I think a "Cadillac" q- jet cam be rebuild to work well on a 350/383. No doubt more experienced people will come around.
350/383.
Got 4 of those in my basement.
Piece of advice from Lars. DO NOT buy a commercial rebuilt QJet. If you don't have one already, the best ones are usually the ones nobody has messed with, covered in grease. Buy a few for parts. Problem with the commercial rebuilts are they are often modified, parts from different carbs mixed together, and some internal parts changed, impossible even for Lars to tell if the internals are correct since their not documented or numbered.
Based on my recent experience it seems the jets and metering rods can be changed to get the carb in the ballpark for your application. Whether it will be optimal I don't know.
I've seen the fuel inlet in different locations, thought the ones which weren't on the side were non Chevrolets?
Hey Alan. From what little I know, only Chevys had the 90* fuel inlet fitting. Pontiac, Cadillac and Oldsmobuick had a straight out the front fitting. Ford also ran a Q-Jet on some Mustangs/Cougars. They are out the front also. I have never seen one of those in person. I would think there are more Chevys than the rest combined. mike...
To address 7T1vette's comments about swapping parts and coming up with a carb that works for your application. I believe that he is correct.
Someone with a good understanding of the Quadrajet, can no doubt do this. However, I believe one of the reasons that the Quadrajet has developed such a nefarious reputation is that typically someone that doesn't understand the Quadrajet well tries that very thing and doesn't get it right. The result is a mix-master of parts that very often will never work well together.
General Motors adapted the Quadrajet to operate on such a broad spectrum of cars with different weights, transmissions, driving and even emissions requirements by changing various aspects of the Quadrajet to accomplish this. Frankly they did a great job and as a result there are many, many Quadrajets out there that all appear the same on the outside, but internally they are really quite different.
As I mentioned earlier, if you get access to a copy of Cliff's book you will better understand just how GM did this and why the Quadrajet numbers can be so important. Can Lars or Cliff or someone with their experience swap out a bunch of parts and make it work well, sure. But can the average backyard mechanic delve into a Quadrajet he finds at a swap meet (that turns out to come from a Buick station wagon ?) and get it to perform like an original carb on his 1975, L-48, I doubt it. And that gentlemen is why so many folks abandon their Quadrajet for something that has less overall capability.
Good luck... GUSTO
