Having trouble finding a GOOD thermostat...
Old Jun 13, 2011 | 11:55 PM
VCuomo's Avatar
VCuomo
Originally Posted by ...Roger...
Hows that work ?
Not 100% sure, but I read it here...
I found this in an old post from BarryK:
Originally Posted by BarryK
"The difference in the t-stats themselves is that if they fail, the Robert Shaw fails "open" to keep coolant flowing where most others fail closed restricting the coolant and causing you to overheat. The RS units are what called a dual flow path and it's the extra flow path that allopws the coolant to flow if it fails"
