reverse light hook up
Old Jun 17, 2011 | 01:09 PM
forman's Avatar
forman
Default reverse light hook up
anyone have pictures of how the reverse light switch hooks up to the shift linkage ,4 speed it s a 1970 thanks
Old Jun 17, 2011 | 03:07 PM
Alan 71's Avatar
Alan 71
Hi F,
It's really pretty easy.
The bracket and switch attach to the driver's side cover on the transmission.
It uses two of the cover's regular bolts. The last one back on the bottom row, and the first one above it.
The linkage attaches to the tiny hole in the reverse lever with a tiny clip.
It's shown in the AIM in UPC 12, Sheet C 3.
Good Luck!
Regards,
Alan
Old Jun 17, 2011 | 03:28 PM
forman's Avatar
forman
will it also work on a hurst set up Alan thanks Terry
Old Jun 17, 2011 | 04:04 PM
...Roger...'s Avatar
...Roger...
Yes it will work providing you use the factory reverse lever with the hole in it.
Old Jun 17, 2011 | 11:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This should help.. And 6 in the picture is just a shield.. Most people see it and ask..
To reverse light hook up
